| no1uno |
Jan 2 2013, 08:36 PM
Member ![]() ![]() Group: Members Posts: 206 Joined: 2-December 10 From: Melbourne, FL Member No.: 12,448 Region Association: South East States |
I'm trying to help my father get a project 914 started. It hasn't been started in a year. We tried to install a new battery over the weekend. First, we installed the positive terminal. When we went to install the negative terminal there was a larger than usual pop/spark and a sizzling sound. Within seconds, it began to smell and the battery cables themselves got very hot. It's as if there is high, ongoing load as soon as the negative connection is made. Any ideas? The fuses under dash look fine. The blue 25amp on engine relay board was blown. I replaced it but had the same problem. A bad ground, perhaps? What could draw so much power so quickly?
Thanks in advance for your advice. |
| ednosnaws |
Jan 2 2013, 08:40 PM
Newbie ![]() Group: Members Posts: 17 Joined: 20-November 12 From: San Diego, CA Member No.: 15,171 Region Association: Southern California |
I'm trying to help my father get a project 914 started. It hasn't been started in a year. We tried to install a new battery over the weekend. First, we installed the positive terminal. When we went to install the negative terminal there was a larger than usual pop/spark and a sizzling sound. Within seconds, it began to smell and the battery cables themselves got very hot. It's as if there is high, ongoing load as soon as the negative connection is made. Any ideas? The fuses under dash look fine. The blue 25amp on engine relay board was blown. I replaced it but had the same problem. A bad ground, perhaps? What could draw so much power so quickly? Thanks in advance for your advice. Have you switched the terminals by accident? |
| Mike Bellis |
Jan 2 2013, 08:50 PM
Resident Electrician ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,347 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None
Pull all the fuses and try again. Replace 1 fuse at a time until you find where the load is. If you still have spark without fuses, something is grounded that shouldn't be.
| no1uno |
Jan 2 2013, 09:13 PM
Ok. Thanks. I will try pulling all the fuses to see what i've got
| rfuerst911sc |
Jan 3 2013, 04:58 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,158 Joined: 4-May 06 From: Dahlonega , Georgia Member No.: 5,980 Region Association: South East States |
A bad starter solenoid ? Headlight motors ? Wiper motors ? These are the only items I can think of that could draw enough current to heat up the battery cables. Be very careful a battery packs a LOT of explosive power !
| Spoke |
Jan 3 2013, 09:57 AM
Jerry ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,355 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None
If the battery cables got hot, its likely not anything in the fuse box. Something would have smoked long before the cables got hot.
Check wiring to the alternator and starter. Look for frayed wires. |
| Cap'n Krusty |
Jan 3 2013, 11:20 AM
Cap'n Krusty ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,794 Joined: 24-June 04 From: Santa Maria, CA Member No.: 2,246 Region Association: Central California |
(1) Bad starter. I've seen it before.
(2) Bad alternator. Much less likely. (3) A major short to ground in someplace other than the above. You're pulling a LOT more amps than anything fused. The Cap'n |
| Nine_14 |
Jan 3 2013, 11:58 AM
Member ![]() ![]() Group: Members Posts: 311 Joined: 30-August 12 From: Germany Member No.: 14,873 Region Association: Germany |
(1) Bad starter. I've seen it before. (2) Bad alternator. Much less likely. (3) A major short to ground in someplace other than the above. You're pulling a LOT more amps than anything fused. The Cap'n (IMG:style_emoticons/default/agree.gif) |
| damesandhotrods |
Jan 3 2013, 12:17 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 568 Joined: 26-September 10 From: Santa Cruz California Member No.: 12,218 Region Association: Northern California |
A direct short to ground would result in smoke and burned wiring. A warm cable is a controlled path to ground. It sounds like your battery is seeing ground through something.
| Nine_14 |
Jan 3 2013, 01:50 PM
Disconnect the starter, (main connection) put all those wires together, by a 8mm scew and nut, make shure not having ground contact, connect your battery again and see what's happening.
If all other electric consumers are working fine, you need a new starter. |
| Tom |
Jan 3 2013, 02:02 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,139 Joined: 21-August 05 From: Port Orchard, WA 98367 Member No.: 4,626 Region Association: None |
Which wires got hot? Black large battery cables or red wires at positive battery connector that go to the wiring harness?
Tom |
| 442nd914s |
Jan 3 2013, 05:08 PM
Member ![]() ![]() Group: Members Posts: 139 Joined: 25-July 12 From: KC Suburb Member No.: 14,718 Region Association: None |
If its all original wiring, I would start by:
Disconnect both terminals at the battery. Remove battery Continuity check as follows; Negative terminal to a few ground points. This will verify a good ground terminal connection. Disconnect all 2-3 (possibly more) red/accessory cables from the possitive terminals. You should only have the possitive terminal remaining. Disconnect terminals at the starter. Now all these disconnections, you can do a continuity check to ground. Check from ground to all positive wires, your results should be all open. Which ever wire gets u a "close/ohm” reading, THATS wire is shorted to ground. Follow it with a small grip to check for chaffing or possible strans protruding. In my experiance with my 73, the positive terminal at the starter missing its cover and bent so tight it was approching disaster. Wouldnt hurt to check your battery since you have the meter out. Possibly a bad cell or missed marked post. Most auto parts stores check batteries for free with a load on it. This is more acurate. Good luck |
| 442nd914s |
Jan 4 2013, 12:37 PM
| no1uno |
Jan 4 2013, 12:55 PM
Thanks for all the help. I'll be there this weekend to give it a shot.
| Rusty |
Jan 5 2013, 07:48 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 7,993 Joined: 24-December 02 From: North Alabama Member No.: 6 Region Association: South East States
Any luck with your problem?
Is it possible that you hooked up the battery incorrectly, even for a moment, and shorted the alternator. I did a dumbass thing when jumping my 914 a couple years ago... messed up the jumper cables. Popped the alternator and when I installed a replacement incorrectly, it warmed up the battery & cable because it was grounding out. |
Lo-Fi Version | Time is now: 16th March 2026 - 03:57 AM |
