Impeller Housing, Cheap Casting? |
Allan |
Nov 14 2004, 08:36 PM
Teenerless Weenie Group: Members Posts: 8,373 Joined: 5-July 04 From: Western Mesopotamia Member No.: 2,304 Region Association: Southern California |
Just pulled the impeller housing apart (At least I think that's what it's called). You know the big 2 piece doohickey that bolts onto the end of the motor that the fan sits in. The inside of mine is really rough and cratered like a bad junior high aluminum casting project. The outside looks good. Is it just the way they are made or should the inside be as smooth as the outside?
SirAndy |
Nov 14 2004, 08:40 PM
Resident German Group: Admin Posts: 41,651 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
QUOTE(Headrage @ Nov 14 2004, 07:36 PM) Is it just the way they are made or should the inside be as smooth as the outside? that's the way they are made ... you can actually increase the air-flow (and thus cooling) by making that surface smooth. some people even powder-coat the inside ... (IMG:style_emoticons/default/wink.gif) Andy |
Lo-Fi Version | Time is now: 22nd May 2024 - 11:57 PM |
