Sway Bar Bolts |
Sway Bar Bolts |
jesiv |
May 7 2013, 08:22 PM
Senior Member Group: Members Posts: 552 Joined: 5-August 07 From: Pensacola/Milton, Florida Member No.: 7,975 Region Association: Northern California |
So I have all the parts to install my front sway bar on my 1975 1.8 What I don't have are the bolts. Does anyone know the sizes, hardness, length, etc or someone who sells a kit?
Regards James |
dfelz |
May 7 2013, 09:22 PM
beach bum Group: Members Posts: 419 Joined: 7-June 12 From: San Diego Member No.: 14,538 Region Association: Southern California |
So I have all the parts to install my front sway bar on my 1975 1.8 What I don't have are the bolts. Does anyone know the sizes, hardness, length, etc or someone who sells a kit? Regards James Depends on your nut backing plate, OEM ones didnt have nuts welded on but used M8x1.0 nuts, 30mm hex head bolts and split lock washers. Some of the nut backing plates with nuts welded on use M8x1.25 nuts, so what do you have as far as that goes? |
jesiv |
May 8 2013, 09:32 AM
I have the backing plates squared away. What I need is the bolts for the sway bar linkage
Lo-Fi Version | Time is now: 3rd June 2024 - 02:45 AM |
