| Nor.Cal.914 |
May 20 2013, 10:01 AM
1975 914 3.0SC ![]() ![]() ![]() Group: Members Posts: 1,062 Joined: 28-January 05 From: Weatherford, TX Member No.: 3,523 Region Association: None |
I've been doing some research for moving the ignition switch on a 914-4 to the proper place on the left side of the dash and am looking for a price check or possible purchase for a complete early 911 steering column. The couple threads that I found have mentioned using early 70's columns so that would be what I am looking for. Please let me know what you have! Thank you!
-Chris |
| tweet |
May 20 2013, 10:06 AM
Member ![]() ![]() Group: Members Posts: 200 Joined: 25-February 13 From: South Florida Member No.: 15,579 Region Association: South East States |
I've been doing some research for moving the ignition switch on a 914-4 to the proper place on the left side of the dash and am looking for a price check or possible purchase for a complete early 911 steering column. The couple threads that I found have mentioned using early 70's columns so that would be what I am looking for. Please let me know what you have! Thank you! -Chris If none of the members have it here, you can always try TheSamba or Pelican. |
| bdstone914 |
May 20 2013, 10:19 AM
bdstone914 ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,321 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
I've been doing some research for moving the ignition switch on a 914-4 to the proper place on the left side of the dash and am looking for a price check or possible purchase for a complete early 911 steering column. The couple threads that I found have mentioned using early 70's columns so that would be what I am looking for. Please let me know what you have! Thank you! -Chris Anywhere from $10 - $100. Just got some parts from ebay. The steering column bearing is over $100 new and are often bad. Bruce |
| Nor.Cal.914 |
May 20 2013, 10:23 AM
| bdstone914 |
May 20 2013, 10:26 AM
I should have a 911 column with shaft, a 4 shaft to rob the mount from, an ignition switch, and 911 clamshells if you are interested in doing this.
| Nor.Cal.914 |
May 20 2013, 10:29 AM
| Harpo |
May 20 2013, 06:01 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,304 Joined: 21-August 11 From: Motor City aka Detroit Member No.: 13,469 Region Association: None |
I have an extra 914/6 clone column if necessary
DAvid |
Lo-Fi Version | Time is now: 9th June 2026 - 01:41 PM |
