Plug Air Injection Tubes on 2.0 Motor |
mdelwiche |
Jun 1 2013, 12:35 PM
Vegas_914 Group: Members Posts: 59 Joined: 17-March 12 From: Tucson, AZ Member No.: 14,266 Region Association: Southwest Region |
Does anyone have an idea of what to size or type of bolt to use to plug the holes where the air injection tubes go? I am rebuilding my 2.0L motor and do not plan on reinstalling all the emissions equipment.
76-914 |
Jun 1 2013, 01:08 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,507 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
Don't know the metric size in the head to plug. That was covered here in the last few months. I'm not good at searches. If you re-use the nipple then a 3/8" pipe cap will screw on the end.
Drums66 |
Jun 1 2013, 01:34 PM
914 Rudiments Group: Members Posts: 5,321 Joined: 15-January 03 From: Coronado,Cali Member No.: 151 Region Association: Southwest Region |
.....I don't know the details?but.there is also a copper
plug that is used. that i've seen on heads that were done on my cars! (IMG:style_emoticons/default/idea.gif) (IMG:style_emoticons/default/bye1.gif) |
mdelwiche |
Jun 1 2013, 01:49 PM
One of the air tubes was torn up pretty good when I removed it because it had rusted into place and is not re-usable...otherwise I would get the caps--unless I can find another one, but so far they have been pretty hard to find and/or way to expensive for my taste.
r_towle |
Jun 1 2013, 03:15 PM
Custom Member Group: Members Posts: 24,585 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Bring the tube to the hardware store.....it's not a special order bolt.
Rich |
Krieger |
Jun 1 2013, 06:50 PM
Advanced Member Group: Members Posts: 4,723 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None |
Call Engine Builders Supply in Reno. IIRC they are the same plugs 911s use.
McMark |
Jun 1 2013, 08:30 PM
The threads are M10x1.00. A bolt of the correct length will work fine. You can get plugs that will go down inside, but I prefer bolts because of the friction of the bolt head will help keep things in place.
brant |
Jun 1 2013, 10:31 PM
914 Wizard Group: Members Posts: 11,632 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
ball bearings and caps (American thread works believe it or not)
go to ace hardware with one of the injection plugs and its easy to piece together |
hedfurst |
Jun 2 2013, 06:59 AM
Member Group: Members Posts: 99 Joined: 9-March 03 From: S. Mississippi Member No.: 406 |
Same size as the 2 Liter valve adjust screw. I have inserted them covered with teflon tape, works well unless the threads are screwed up.
Lo-Fi Version | Time is now: 3rd June 2024 - 01:58 AM |
