914LIVE |
Newbie ![]() Group: Members Posts: 10 Joined: 29-June 10 From: Portland, Oregon. Member No.: 11,890 Region Association: None ![]() |
![]() ![]() ![]() Offering a RARE M.P.S. from a running 2.0 Liter Porsche 914 engine. Unmolested sensor with factory seal and settings. Offered for $ 150 plus actual shipping. PM or Reloportland@aol.com |
Firstcar |
Obsessive amateur mechanic ![]() ![]() Group: Members Posts: 98 Joined: 17-March 11 From: MA -South Shore Member No.: 12,831 Region Association: North East States ![]() |
Has it been tested? PM sent
Firstcar |
bdstone914 |
bdstone914 ![]() ![]() ![]() ![]() Group: Members Posts: 4,537 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 ![]() |
Has it been tested? PM sent Guess not. So we should consider it a core? It is worth the price it it is good. It should hold 15 mg of vacuum. there are two electrical tests to run also. It requires a multimeter. Good luck with the sale. |
914LIVE |
It will be tested. It was just pulled from a PERFECTLY RUNNING 2.0 Liter, so I imagine it is still perfect. When I find the time and a local mechanic/expert to test it, I will let the 914World know. Patience, patience. ========================================== quote name='Firstcar' date='Jun 16 2013, 01:34 PM' post='1880860'] [quote name='Firstcar' post='1879103' date='Jun 12 2013, 10:06 PM'] Has it been tested? PM sent [/quote] Guess not. So we should consider it a core? [/quote] |
type47 |
Viermeister ![]() ![]() ![]() ![]() Group: Members Posts: 4,254 Joined: 7-August 03 From: Vienna, VA Member No.: 994 Region Association: MidAtlantic Region ![]() |
When I find the time and a local mechanic/expert to test it, really just need a multimeter, actually, only an ohm meter, to test 2 resistance values between 2 sets of terminals where the MPS plugs into the harness. You could even suck gently on the vacuum port and put your tongue over the port to see if it holds vacuum... |
DRPHIL914 |
Dr. Phil ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,768 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States ![]() ![]() |
When I find the time and a local mechanic/expert to test it, really just need a multimeter, actually, only an ohm meter, to test 2 resistance values between 2 sets of terminals where the MPS plugs into the harness. You could even suck gently on the vacuum port and put your tongue over the port to see if it holds vacuum... or a brake bleeder/vac which is what i use, not that expensive-- |
Lo-Fi Version | Time is now: 10th June 2024 - 03:11 PM |
