New 1972 Porsche 914 -1.7L Fuel injected, 914 is running like crap, need help. |
Mario Nicola |
Jun 24 2013, 03:35 PM
Newbie Group: Members Posts: 3 Joined: 31-May 13 From: Newmarket, ON Member No.: 15,940 Region Association: None |
Hey Guys.
I just bought a new 1972 Porsche 914 1.7L fuel injected, the previous owner let it sit for 2-3 years in storage... The Car looks great but isn't running very well, I can't get it above 50mph and it's a struggle to get it up to that speed. I have swapped out the plugs, plug wires and air filter and put some new Gas and fuel injector cleaner in the tank but the problem still continues... I was thinking it's time to replace the fuel injectors next... any suggestions on how to fix the problem, or has anybody else run into the same problems with their 914's. Thanks Mario |
r_towle |
Jun 24 2013, 03:48 PM
Custom Member Group: Members Posts: 24,588 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Pbanders site.
Look it up under google. |
SirAndy |
Jun 24 2013, 03:53 PM
Resident German Group: Admin Posts: 41,676 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Pbanders site. (IMG:style_emoticons/default/agree.gif) That site has a lot of good info about the D-Jet. Also, check the tank bottom for rust. Flashlight through the filler neck will do and replace the fuel filter. The injectors can be checked by letting them squirt into a jar. Getting good fuel and spark is half the battle ... (IMG:style_emoticons/default/biggrin.gif) PS: (IMG:style_emoticons/default/welcome.png) |
TheCabinetmaker |
Jun 24 2013, 03:56 PM
I drive my car everyday Group: Members Posts: 8,304 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
First, adjust valves. Then set dwell. Then timing. Then drive it again and report back with the outcome.
jsayre914 |
Jun 24 2013, 04:34 PM
Speed Up !!! Group: Members Posts: 3,188 Joined: 10-February 08 From: Timonium MD 21093 Member No.: 8,696 Region Association: MidAtlantic Region |
Need more info,
It idles well but no power? It doesn't idle and no power? could be all kinds of stuff if it has been sitting. squirll stuck in the exhaust? (IMG:style_emoticons/default/agree.gif) Check valves, timing, compression test, etc |
Lo-Fi Version | Time is now: 7th June 2024 - 06:42 PM |
