Another Gasket Question, Air Temp Sensor |
Allan |
Dec 2 2004, 12:23 PM
Teenerless Weenie Group: Members Posts: 8,373 Joined: 5-July 04 From: Western Mesopotamia Member No.: 2,304 Region Association: Southern California |
Anyone know where I can get the gasket for the temp sensor that mounts to the plenumn? Is there a VW equivalent? Thanks
McMark |
Dec 2 2004, 12:31 PM
Allan |
Dec 2 2004, 12:42 PM
Sorry, I meant this thing.
Attached image(s) |
jim912928 |
Dec 2 2004, 12:46 PM
Senior Member Group: Members Posts: 1,485 Joined: 8-January 04 From: Granger, IN Member No.: 1,536 Region Association: Upper MidWest |
I believe that is the cold-start valve (basically an injector that squirts gas into the plenum when the temp is real cold (can't remember the cutoff). I thing the true temp sensor itself is towards the passenger side rear of the engine (on top).
Allan |
Dec 2 2004, 12:48 PM
Okay then, anyone know where I can get a cold start valve gasket?
lapuwali |
Dec 2 2004, 12:53 PM
Not another one! Group: Benefactors Posts: 4,526 Joined: 1-March 04 From: San Mateo, CA Member No.: 1,743 |
Make one, or just use goop. Little gaskets like that are always a pain to source, and rarely worth the bother.
Perhaps the specs are different on the 914 part, but the thermo-time switch (what controls the cold-start valve) on the K-Jet 911s switched on the valve when the engine temp was below 90dF, which ain't real cold in my book...It only comes on during cranking, and only for a few seconds. |
Allan |
Dec 2 2004, 01:00 PM
Okay thanks. I'll just make one. Whoops it takes two. (IMG:style_emoticons/default/biggrin.gif)
Lo-Fi Version | Time is now: 5th June 2024 - 01:46 PM |
