| Elliot Cannon |
Sep 24 2013, 03:12 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Retired Members Posts: 8,487 Joined: 29-December 06 From: Paso Robles Ca. (Central coast) Member No.: 7,407 Region Association: None
Could this leak be coming from a crack in the head at the valve guide?
| stugray |
Sep 24 2013, 03:48 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,825 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None |
My first thought was that there is nothing up there that can leak oil.
then I took some pics of a head laying right next to me: (IMG:http://www.914world.com/bbs2/uploads_offsite/i366.photobucket.com-10819-1380059313.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i366.photobucket.com-10819-1380059313.2.jpg) So after looking at those pics... If the head nut/stud to the left of the above pic gets really loose, then the oil could leak out where you are showing. AND - B|tch slap whoever put all that sillycone on your pushrod tubes. |
| SirAndy |
Sep 24 2013, 04:05 PM
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 42,469 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
AND - B|tch slap whoever put all that sillycone on your pushrod tubes. (IMG:style_emoticons/default/agree.gif) |
| 0396 |
Sep 24 2013, 04:12 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,046 Joined: 13-October 03 From: L.A. Calif Member No.: 1,245 Region Association: Southern California |
AND - B|tch slap whoever put all that sillycone on your pushrod tubes. (IMG:style_emoticons/default/agree.gif) (IMG:style_emoticons/default/biggrin.gif) |
| Elliot Cannon |
Sep 24 2013, 09:24 PM
I ask for help and I get criticized. Sheesh. I feel like Rodney Dangerfield. (IMG:style_emoticons/default/av-943.gif) No respect. (IMG:style_emoticons/default/lol-2.gif)
| SLITS |
Sep 24 2013, 09:25 PM
"This Utah shit is HARSH!" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None |
I ask for help and I get criticized. Sheesh. I feel like Rodney Dangerfield. (IMG:style_emoticons/default/av-943.gif) No respect. (IMG:style_emoticons/default/lol-2.gif) I tole ya ya shuddin put that krap on dem tubes. Shoddy engine builder. |
| Elliot Cannon |
Sep 25 2013, 02:19 PM
OK, I'm pretty sure the inside of the exhaust port including the valve and valve stem, shouldn't be covered with wet glistening oil. (It's actually worse than the picture shows). All the other exhaust ports are dark grey with carbon but they are totally dry. I need some experienced opinions here unless you just can't help making remarks about silicone and bitch slapping. (IMG:style_emoticons/default/laugh.gif) This is the number 2 exhaust port. I found the smoke the car was making was worse doing down hill with a right turn. Since number 2 is the forward left cylinder I guess this makes sense. Does anyone besides SLITS agree with this? Looks like the engine comes out and the head comes off. (IMG:style_emoticons/default/smash.gif)
| Dave_Darling |
Sep 25 2013, 02:43 PM
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,335 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California
(IMG:style_emoticons/default/sad.gif) I'd agree; time to pull that head and have it checked thoroughly.
--DD |
| r_towle |
Sep 25 2013, 03:03 PM
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,705 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States
could be headwork, could be junk rings.
Pull it, stop taking pictures already.. rich |
| stugray |
Sep 25 2013, 03:15 PM
QUOTE I'm pretty sure the inside of the exhaust port including the valve and valve stem, shouldn't be covered with wet glistening oil. The part that I was commenting on was the drip of oil coming from ABOVE the stub pipe, which cannot be coming from inside the exhaust port. Or do you not see the drip coming off of the cooling fin? I was being serious both about the leak and the fact that you should not use silicone on the tube seals.... Looks like you have a leak both inside & outside that cylinder. Maybe from that bolt AND from inside. Maybe related? |
| Elliot Cannon |
Sep 25 2013, 04:31 PM
| Elliot Cannon |
Sep 25 2013, 04:34 PM
QUOTE I'm pretty sure the inside of the exhaust port including the valve and valve stem, shouldn't be covered with wet glistening oil. The part that I was commenting on was the drip of oil coming from ABOVE the stub pipe, which cannot be coming from inside the exhaust port. Or do you not see the drip coming off of the cooling fin? I was being serious both about the leak and the fact that you should not use silicone on the tube seals.... Looks like you have a leak both inside & outside that cylinder. Maybe from that bolt AND from inside. Maybe related? Thanks. It looks like the engine comes out. (IMG:style_emoticons/default/sad.gif) The push rod tubes aren't leaking and never have on this engine because of the high temp sealant that was used. So, which is better, carbs or fuel injection? |
| SLITS |
Sep 25 2013, 04:37 PM
I would have told you that your guess at a crack valve guide seat would have oiled the port, but you don't listen anyway.
Go sit in your lawn chair, take more pictures, drink wine, eat more moldy cheese, PUT DOWN THE RTV AND TOOLS and wait for the Leprechauns to fix your car. PULL THE DAMN HEAD!!!!! |
| SLITS |
Sep 25 2013, 04:44 PM
| r_towle |
Sep 25 2013, 07:41 PM
I would have told you that your guess at a crack valve guide seat would have oiled the port, but you don't listen anyway. Go sit in your lawn chair, take more pictures, drink wine, eat more moldy cheese, PUT DOWN THE RTV AND TOOLS and wait for the Leprechauns to fix your car. PULL THE DAMN HEAD!!!!! (IMG:style_emoticons/default/agree.gif) And if I lived nearby, I would swing by and pick up SLITS, along with two more chairs, a few extra bottles of wine, some scotch and we would come supervise you while you waited for the leprechauns. |
| StratPlayer |
Sep 25 2013, 08:14 PM
StratPlayer ![]() ![]() ![]() ![]() Group: Members Posts: 3,361 Joined: 27-December 02 From: SLC, Utah Member No.: 27 Region Association: Rocky Mountains
Time for a six elliot (IMG:style_emoticons/default/beer.gif)
| Elliot Cannon |
Sep 25 2013, 10:32 PM
I would have told you that your guess at a crack valve guide seat would have oiled the port, but you don't listen anyway. Go sit in your lawn chair, take more pictures, drink wine, eat more moldy cheese, PUT DOWN THE RTV AND TOOLS and wait for the Leprechauns to fix your car. PULL THE DAMN HEAD!!!!! But you didn't. All you could think of was giving me shit about RTV on the push rod tube seals. Speaking of Leprechauns, does that mean you'll be coming up here to help? (IMG:style_emoticons/default/av-943.gif) |
| Elliot Cannon |
Sep 25 2013, 10:36 PM
I would have told you that your guess at a crack valve guide seat would have oiled the port, but you don't listen anyway. Go sit in your lawn chair, take more pictures, drink wine, eat more moldy cheese, PUT DOWN THE RTV AND TOOLS and wait for the Leprechauns to fix your car. PULL THE DAMN HEAD!!!!! (IMG:style_emoticons/default/agree.gif) And if I lived nearby, I would swing by and pick up SLITS, along with two more chairs, a few extra bottles of wine, some scotch and we would come supervise you while you waited for the leprechauns. Hey! Hey! New England boy. SLITS is the only one who can talk about me like that. Besides if you lived close by, I don't think either one of you would be much help. (IMG:style_emoticons/default/av-943.gif) |
| Elliot Cannon |
Sep 25 2013, 10:37 PM
I'm working on it. I'm looking for one for the 914 as well. (IMG:style_emoticons/default/laugh.gif) |
| Elliot Cannon |
Sep 25 2013, 10:40 PM
So, which is better, carbs or fuel injection? Neither ......... What chicken $hit answer! (IMG:style_emoticons/default/shades.gif) (IMG:style_emoticons/default/laugh.gif) FI is more efficient. Carbs are more fun. (IMG:style_emoticons/default/slap.gif) |
Lo-Fi Version | Time is now: 2nd April 2026 - 11:07 AM |
