knicking reverse |
knicking reverse |
rjames |
Oct 7 2013, 11:10 AM
I'm made of metal Group: Members Posts: 3,955 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest |
Hopefully this is the last chapter my 'shifting improvement' series.
Post trans rebuild and bushing replacements, the car shifts pretty darn good except that it's too easy to nick reverse. I've done too many times it when shifting from 1st to 2nd and when trying to downshift into 2nd. I realized yesterday that I can get into reverse and 1st easily without having to put any extra effort into moving the shifter to the left. Before adjusting the shifter I remember having to put a little effor into getting it over that far. Does the overall amount of resistance that should be felt from the springs get affected by where the shifter is in relation to it's connection to the bar going through the firewall? In other words, if I adjust the shifter such that I have to move it farther to the left to get it into 1st or reverse, will that force more tension on the springs? Did I explain that in english? (IMG:style_emoticons/default/huh.gif) |
Eric_Shea |
Oct 7 2013, 11:34 AM
PMB Performance Group: Admin Posts: 19,278 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
Understood. I doubt the position of the adjustment will give the spring any more or less tension. That said, there are some aftermarket springs out there with more tension.
rjames |
Oct 7 2013, 11:40 AM
Understood. I doubt the position of the adjustment will give the spring any more or less tension. That said, there are some aftermarket springs out there with more tension. Maybe I should be looking for a new lockout plate, too? (I think that's what it's called- need to find a diagram...) |
rhodyguy |
Oct 7 2013, 11:48 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,093 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
reverse lock out plate. #901 424 017 00. check for wear on the bottom of the shift lever at the contact point.
toolguy |
Oct 7 2013, 12:01 PM
Senior Member Group: Members Posts: 1,270 Joined: 2-April 11 From: San Diego / El Cajon Member No.: 12,889 Region Association: Southern California |
Sounds like you need to rotate the adjustment one spline over at the firewall joint.
r_towle |
Oct 7 2013, 01:47 PM
Custom Member Group: Members Posts: 24,591 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
flip the shifter into neutral.
Which gate are you in? r-1 2-3 4-5 When the rotation is correct (and it sounds like your is not) you will always land in the 2-3 gate when flipped into neutral. You need to push it to r-1 or 4-5 How I do it... Grab the wifes white nail polish. Mark the rod where it goes into the front coupler at the shifter. Now you know where that is right...you should never see unpainted metal. Scratch a mark on both the top of the rod and the top of the coupler. Now, looking forward, rotate the rod clockwise one tooth at a time...which it a tiny amount...less than 1/16 if an inch. Lock it down and try it. Come back and do a bit more. I typically do this with the rear access plate removed and a pair of vice grips and a socket wrench with me. From the rear access plate, use the vice grips to hold the rod. Use the socket to loosed it. With the paint marks and scratches, its easy to see. Its a drive and adjust thing....takes a few times and you will be all done. Rich |
aircooledtechguy |
Oct 7 2013, 06:11 PM
The Aircooledtech Guy Group: Members Posts: 1,966 Joined: 8-November 08 From: Anacortes, WA Member No.: 9,730 Region Association: Pacific Northwest |
flip the shifter into neutral. Which gate are you in? r-1 2-3 4-5 When the rotation is correct (and it sounds like your is not) you will always land in the 2-3 gate when flipped into neutral. You need to push it to r-1 or 4-5 How I do it... Grab the wifes white nail polish. Mark the rod where it goes into the front coupler at the shifter. Now you know where that is right...you should never see unpainted metal. Scratch a mark on both the top of the rod and the top of the coupler. Now, looking forward, rotate the rod clockwise one tooth at a time...which it a tiny amount...less than 1/16 if an inch. Lock it down and try it. Come back and do a bit more. I typically do this with the rear access plate removed and a pair of vice grips and a socket wrench with me. From the rear access plate, use the vice grips to hold the rod. Use the socket to loosed it. With the paint marks and scratches, its easy to see. Its a drive and adjust thing....takes a few times and you will be all done. Rich (IMG:style_emoticons/default/agree.gif) Sounds like you just need to slightly re-adjust the shifter on the shift rod. |
Dr Evil |
Oct 8 2013, 08:28 PM
Send me your transmission! Group: Members Posts: 23,002 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region |
As long as the rod, plate, and springs are in good order, place the trans in 2 or 3 and then adjust so your shifter is pressing against the spring plate. This should resolve your problem.
Lo-Fi Version | Time is now: 10th June 2024 - 02:39 AM |
