CV Joint boots |
CV Joint boots |
Jesco Reient |
Oct 18 2013, 10:31 AM
Member Group: Members Posts: 135 Joined: 18-July 12 From: Western Washington Member No.: 14,690 Region Association: Pacific Northwest |
OK the CV joints are NLA, how about what is everyone using for boots after cleaning and rebuilding?
Thank you in advance |
914_teener |
Oct 18 2013, 11:04 AM
914 Guru Group: Members Posts: 5,201 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
The boots are widely available. Lobro still makes them I believe.
Make sure you get the right washers and stick them on the right way. As far as rebuilding....as far as I know.... once a bearing is gone....it is gone. I used new Type I's. Chris Foley at Tangerine machines recesses in them for the gaskets. Good luck. |
Jesco Reient |
Oct 18 2013, 02:50 PM
Thank You for the tip.
mrbubblehead |
Oct 18 2013, 03:15 PM
Twodollardoug Group: Members Posts: 1,155 Joined: 17-December 10 From: calimesa ca. Member No.: 12,492 Region Association: Southern California |
if you can find an old original set of 2 piece boots. (picture) ones that the flange seperates from the boot, than i recommend rockford driveline boots. they are way thicker and made of better rubber than the new german or brazilian boots. i got sick of replacing boots every 5k miles. the rockfords are well over 10k now and feel brand new.
(IMG:http://www.914world.com/bbs2/uploads_offsite/i722.photobucket.com-12492-1382130946.1.jpg) |
Lo-Fi Version | Time is now: 1st June 2024 - 06:48 AM |
