wndsnd |
You wanted a horse, but got a goat. Nobody wants a goat.... ![]() ![]() ![]() ![]() Group: Members Posts: 2,861 Joined: 12-February 12 From: North Shore, MA Member No.: 14,124 Region Association: North East States ![]() ![]() |
Oil temp is cool, heads are running hot.
What are the top five ..... |
brant |
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,021 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains ![]() ![]() ![]() |
Timing
AF ratio |
wndsnd |
brant |
Advanced.
And idle screws adjust idle. Jets take over under load which is where heat is created. Also check for blockage in your cooling fan |
dfelz |
beach bum ![]() ![]() Group: Members Posts: 419 Joined: 7-June 12 From: San Diego Member No.: 14,538 Region Association: Southern California ![]() ![]() |
Advanced. And idle screws adjust idle. Jets take over under load which is where heat is created. Also check for blockage in your cooling fan I have been told too retarded will send more heat to the heads. I would imagine both sides of the spectrum would result in hotter heads. |
McMark |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 20,180 Joined: 13-March 03 From: Grand Rapids, MI Member No.: 419 Region Association: None ![]() |
How hot?
Mark Henry |
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada ![]() |
mice
ConeDodger |
Apex killer! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,118 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California ![]() ![]() |
Even in a perfect tune, head temps go up when you are driving uphill or under a sustained load.
wndsnd |
wndsnd |
wndsnd |
Just rejetted the mains, and got the temps down substantially. I am working close to Erics calculations now.
But now It bogs down, so I think I may have overdone it. Also I adjusted the Idle mixture screws a bit richer. (Not the idle speed screws). I also have a AF guage, but not sure what I am reading, or where it should be. It fluctuates all over from 9.5 to 18. Getting head temps of 350 - 375. Was over 450 (IMG:style_emoticons/default/icon8.gif) This is the dANNY engine, so if it blows, it blows. I just need to get it to Tangerine tomorrow and at2 1/2 hours of freeway speeds, I needed to get the temps down, or I would be calling AAA. I might have to call them anyway. |
wndsnd |
McMark |
You really shouldn't see anything over 16. 18 is too lean.
You really shouldn't see anything under 12. 9.5 is too rich. I bet your carbs are out of sync as well. |
76-914 |
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,757 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California ![]() ![]() |
Did you verify the temp reading.
wndsnd |
wndsnd |
PanelBilly |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,907 Joined: 23-July 06 From: Kent, Wa Member No.: 6,488 Region Association: Pacific Northwest ![]() ![]() |
Harbor Freight has the infrared guns on sale tomorrow
wndsnd |
Probably wouldn't help because head temps change so quickly. And when they are loaded you are moving
Kirmizi |
Senior Member ![]() ![]() ![]() Group: Members Posts: 836 Joined: 12-February 06 From: Wyoming, US Member No.: 5,568 Region Association: None ![]() |
Is the thermostat installed and what is the position of your cooling flaps?
914itis |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,892 Joined: 9-October 10 From: New York City Member No.: 12,256 Region Association: North East States ![]() |
Lo-Fi Version | Time is now: 31st July 2025 - 05:45 PM |
