FS 3 barrell Weber carb parts - basket cases |
bdstone914 |
Dec 14 2013, 11:50 AM
bdstone914 Group: Members Posts: 4,529 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
I have posted these 3 barrel Weber carbs on Pelican and Early S Registry.
I can get more details and pictures if needed. Bruce http://www.early911sregistry.org/forums/sh...a-Zenith-40-TIN Bruce Sale pending on Weber parts. Zenith still available. I have a bunch of 40 Weber carbs that I would like to sell as a lot. The best One 40 IDT P13C. It was missing the auxiliary venturis but was otherwise a functional carb. One carb marked 40IDS 3C. It has 46mm butterflies. Bare other than the throttle shafts and butterflies. The worst. Weber 40 IDA 3C1 and a 40IDA 3C. Both had stuck throttle shafts and many problems. I got the throttle shafts out by cutting them in sections. The previous owner broke off different plugs and covered them with JB Weld. I got the JB off and found the broken parts below. The large brass hex nuts are stuck. I do have two other tops with good plugs.' They have seen water and will need a lot of work. I found the Pierce Manifolds has the throttle shafts for about $177 per carb. There are at least two good floats. I would like $650 or best offer for all the Weber carbs and parts. Last is a Zenith 40 TIN. it is missing the auxiliary venturies and a banjo bolt. Asking $100 for it |
Lo-Fi Version | Time is now: 31st May 2024 - 07:54 PM |
