tumamilhem |
LUFTBRIGADE ![]() ![]() ![]() Group: Members Posts: 1,228 Joined: 29-October 12 From: Jacksonville, FL Member No.: 15,092 Region Association: South East States ![]() |
Apparently the computer in my 1974 2.0 is not working properly and making the car run rich. Does anybody know where I can find another one or who to go to have mine rebuilt? It's for a 1974 2.0 with D-jet fuel injection.
Also my 3rd cylinder is misfiring. Would this have anything to do with the computer? If not, any idea what may be causing it to misfire? I have a new working AAR valve installed, my MPS works, no bad wiring in the wire harness or spark plug wires, the timing and dwell are on point and the valves are adjusted. (IMG:style_emoticons/default/confused24.gif) |
brant |
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,010 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains ![]() ![]() ![]() |
there should be someone with one in the classifieds
I'm surprised, but anything is possible. did you ever put an ohm meter on the cht to 100% rule out that the new one you installed wasn't faulty? |
JawjaPorsche |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,463 Joined: 23-July 11 From: Clayton, Georgia Member No.: 13,351 Region Association: South East States ![]() |
Pelican Parts
http://www.pelicanparts.com/cgi-bin/smart/...C%2520Each%2520 Have you had your injectors cleaned? |
tumamilhem |
Yes, CHTS ohm reading checks out fine and the injectors are clean. Car was not misfiring before. Idle issue before was the AAR valve. Which was also causing the car to not start once it got hot. My mechanic took it for a drive after and those issues (seemed) to be resolved (will really know about the car not starting once hot after I drive it for a while). But during the test drive, he said the 3rd cylinder started misfiring. New issue I guess. :/
brant |
I believe the computer is only for adjusting and measuring fuel
I don't believe it has anything to do with spark pull the offending plug and check plug condition too much fuel could of fouled it? but that heavy amount of fuel would still likely point back to the CHT or MPS. put a spare plug into the wire and check for spark or better yet, put a timing light onto the wire and check for spark. brant |
tumamilhem |
Thanks for the tip, Brant. He checked the plugs. They are dry and look good and sparking. CHTS is new and working and MPS is working (was tested by Jeff Bowlsby). The only thing he has found in his research is faulty wiring or bad computer. The wiring is fine so he is assuming it is the computer by process of elimination. Everything else is working as it should. Is there any way to test the computer?
914itis |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,892 Joined: 9-October 10 From: New York City Member No.: 12,256 Region Association: North East States ![]() |
What's the part number on the computer? I may have one
rhodyguy |
Chimp Sanctuary NW. Check it out. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 22,249 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch ![]() |
post the ecu #. (IMG:style_emoticons/default/agree.gif)
JeffBowlsby |
914 Wiring Harnesses & Beekeeper ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,972 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None ![]() ![]() |
Could be a bad injector on #3...was that checked for consistency and spray pattern? Also, the ignition wires can mess with the fuel injection wiring (EMI) if they are in close proximity...especially the #3. Is the wiring separated?
On the FI harness, if you would want to send it to me I would be happy to check it out to see if it needs anything at no cost other than shipping both ways. |
euro911 |
Retired & living the dream. God help me if I wake up! ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,911 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California ![]() ![]() |
Check/clean the trigger points?
SirAndy |
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 42,257 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California ![]() |
Apparently the computer in my 1974 2.0 is not working properly and making the car run rich I highly doubt it. They *rarely* ever go bad. And it's not really a "computer" either, there really aren't any sophisticated electronics inside at all. My money would be on either one or more faulty sensors or broken wiring. (IMG:style_emoticons/default/popcorn[1].gif) |
euro911 |
Jeff, don't you have an ECU test board/box?
r_towle |
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,705 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States ![]() ![]() |
Apparently the computer in my 1974 2.0 is not working properly and making the car run rich I highly doubt it. They *rarely* ever go bad. And it's not really a "computer" either, there really aren't any sophisticated electronics inside at all. My money would be on either one or more faulty sensors or broken wiring. (IMG:style_emoticons/default/popcorn[1].gif) (IMG:style_emoticons/default/agree.gif) You should listen to the advice here, it's most likely not the ECU, which is hardware a/f maps the work or do not. There is no way an ECU could affect tuning. Inputs are Cylinder head temp sensor Throttle position switch Manifold pressure sensor Ambient air temp sensor If this have all be properly checked, and the FI wiring harness has been checked, along with your ground connections and the fuel pressure, it will be an ignition issue. Two things mentioned Injectors sometimes get dirty after 40 years and can stick open Cold start injectors can stick open all the time and spray in raw fuel Both of these things can also make it run rich. Not sure of your location, but there may be better mechanics to bring your car to that are more familiar with D-jet fuel injection. It's not complicated, and everything can be tested in an hour or so to rule out part replacement methodology |
r_towle |
Just saw you are in Jacksonville Florida.
How close are you to series9 shop? Joe Sharp just moved there to work at the shop and those two know djet tuning in their sleep. |
stugray |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,825 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None ![]() |
I have a complete 2.0L FI system with ECU, 5 Green injectors, and all sensors + harness.
I would be willing to part with the entire system, but I do not even know an approximate value. |
rhodyguy |
i would talk to one of the 2 joes at SERIES9. buy new injector seals. they're cheap. and talk to stu.
Cap'n Krusty |
Cap'n Krusty ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,794 Joined: 24-June 04 From: Santa Maria, CA Member No.: 2,246 Region Association: Central California ![]() |
Make sure ALL the ground wires under the intake plenum are secure on the tabs AND that the wiring integrity at the crimped on connectors is good. Harnesses age, just like everything else, and a compromised ground will certainly cause the symptoms you describe.
The Cap'n |
JeffBowlsby |
Ferg |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,948 Joined: 8-January 03 From: Boulder CO Member No.: 116 Region Association: None ![]() ![]() |
I have one for I think a 73 2.0
part # 0 280 000 037 has not been tested. Ferg |
r_towle |
I have two bosch Djet test machines if you think that would work.
rich Attached image(s) ![]() |
Lo-Fi Version | Time is now: 9th July 2025 - 01:11 PM |
