New tires |
New tires |
19732.0 |
Apr 23 2014, 09:08 AM
Newbie Group: Members Posts: 15 Joined: 1-May 13 From: Detroit Member No.: 15,821 Region Association: None |
It's time for me to replace the old, cracking Pirellis on my 914. My car has 5.5-inch, four-bolt Fuchs. The current tires are 165/80-15s. I've been told that the Sumitomo HTR A/S P01s are pretty decent. They're offered in 195/60-15, 185/65-15, or 195/65-15 sizes. I think any of them will fit under my narrow-body.
Anyone have any recommendations for tires: brand, model or size? I won't be autocrossing the thing and neither will I drive the car in heavy rain or snow. So a high-performance all-season or even summer tire would work fine. |
JawjaPorsche |
Apr 23 2014, 09:31 AM
Advanced Member Group: Members Posts: 3,463 Joined: 23-July 11 From: Clayton, Georgia Member No.: 13,351 Region Association: South East States |
I have 195/60/15 with 4 bolt Mahle's and have no clearance problems. In fact, plenty of room.
Attached image(s) |
boxsterfan |
Apr 23 2014, 10:04 AM
914's are kewl Group: Members Posts: 1,776 Joined: 6-June 03 From: San Ramon, CA Member No.: 791 Region Association: Northern California |
I have 205/60/15's on all four corners without flares running on 2.0L Fuch's rims. Rears are fine. If I do a full lock left or right turn, the fronts appear to rub some (as is evident by rub marks in the inner wheel well.)
I like how the 205/60/15's fill-out the space. |
Larmo63 |
Apr 23 2014, 10:52 AM
Advanced Member Group: Members Posts: 4,264 Joined: 3-March 14 From: San Clemente, Ca Member No.: 17,068 Region Association: Southern California |
I just installed Yokohama's 205/65 x 15 on stock Fuchs with stock fenders. They are for some reason a bit closer on the right side, with a bit more room on the left. (?) They look fat on the car and fill the wheel wells perfectly.
Johny Blackstain |
Apr 23 2014, 11:04 AM
Walnut Elite Stratocaster player Group: Members Posts: 3,434 Joined: 5-December 06 From: The Shenandoah River Member No.: 7,318 Region Association: MidAtlantic Region |
My LE came w/ Dunlop SPs so I wanted to put Dunlops back on & used the tire calculator here on the world to make sure my speedo would register correctly. Wound up using Dunlop SP Sport A2 plus in 195/65 x15 on my Mahles. No issues with the fit @ all & according to the calculator virtually the same diameter as my originals.
rgolia |
Apr 23 2014, 01:07 PM
GeoJoe Group: Members Posts: 705 Joined: 5-February 10 From: PA Member No.: 11,329 Region Association: North East States |
I like the look of 185/70s...very close to the originals but wider. They will be replacing my 195/65s real soon.
ipadstott |
Apr 23 2014, 03:01 PM
Ian Stott Group: Members Posts: 27 Joined: 2-April 14 From: Moncton Canada Member No.: 17,192 Region Association: Canada |
I have Bridgestone Potanza 205 60 15's on 4 bolt Fuchs, nice tire, no clearance issues and do the same kind of driving you say you do.
Ian Stott Moncton Canada |
Old Yella |
Apr 23 2014, 04:28 PM
Old Yella Group: Members Posts: 158 Joined: 2-July 13 From: Canberra Australia Member No.: 16,086 Region Association: Southwest Region |
Also have Bridgstone Potenza's and am very happy
195,60,15 on mahle wheels They do rub a little on the inner front wheel wells at full lock, it's not an issue though. I also was considering the 65 profile as the speedo is out by about 4 miles/hour I think. Probably would go the 65's if I bought them again. I'm getting old and also like a bit of comfort in the ride. I have Bridgestone Potanza 205 60 15's on 4 bolt Fuchs, nice tire, no clearance issues and do the same kind of driving you say you do. Ian Stott Moncton Canada |
ndfrigi |
Apr 23 2014, 05:57 PM
Advanced Member Group: Members Posts: 2,933 Joined: 21-August 11 From: Orange County Member No.: 13,474 Region Association: Southern California |
Sorry to hijack your thread ID 19732.0.
I'm also looking for a tire for street driving only like 19732.0 mentioned above. Can also please share a pictures of those tires from the rear to see how much wide 205 or maybe 195 is. since I'm also checking new tires for my narrow body and going to use 2.0 Fuchs wheels. Currently I have riviera wheels with 185x65x15 and I did pull rear driver side fender about 1/4 inch. Thanks and God bless! |
Dave_Darling |
Apr 24 2014, 09:55 AM
There are a number of different Rivs out there. Some will fit 205s under stock (or very slightly modified) 914 fenders, while others make even 165s a tight squeeze. Sounds like your wheels are closer to the latter than the former. There's a good chance that they were intended for a VW Bug, so the wheel is too far out in the fender.
I would suggest either sticking with 185s (or narrower!), or getting some 914 wheels. --DD |
Lo-Fi Version | Time is now: 8th June 2024 - 10:32 AM |
