front hubs, 911/944 front hub interchangability |
cooler |
Apr 29 2014, 09:49 PM
"Very Interesting!" Group: Members Posts: 31 Joined: 6-December 11 From: British Columbia Member No.: 13,865 Region Association: Canada |
Has anyone used 944 hubs on 911 spindles? It appears that the bearings/seals and rotors share the same part numbers. 944 hubs are cheap like borsch 911 are rare and pricy in Canada.
bdstone914 |
May 6 2014, 09:50 PM
bdstone914 Group: Members Posts: 4,534 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
Has anyone used 944 hubs on 911 spindles? It appears that the bearings/seals and rotors share the same part numbers. 944 hubs are cheap like borsch 911 are rare and pricy in Canada. 944 hubs fit on 911 spindles but are not as tall causing the tire to rub on the strut with stock size wheels. You can use longer studs and spacers. I helped a member correct this problem We used 50mm studs and 1/4 inch spacers. |
Lo-Fi Version | Time is now: 4th June 2024 - 03:56 PM |
