| ripper911 |
May 17 2014, 07:45 PM
corde pulsum tangite ![]() ![]() ![]() ![]() Group: Members Posts: 2,920 Joined: 25-April 10 From: Powder Springs, GA Member No.: 11,654 Region Association: South East States |
What are the chances that I could just tighten the nuts which hold the heat exchangers on without pulling the studs out?
I'm about to set the car up for a morning valve adjustment and figured I'd spray the exhaust nuts with pb blaster and let it soak overnight in hopes of tightening them up. |
| r_towle |
May 17 2014, 07:50 PM
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,705 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States
What are the chances that I could just tighten the nuts which hold the heat exchangers on without pulling the studs out? I'm about to set the car up for a morning valve adjustment and figured I'd spray the exhaust nuts with pb blaster and let it soak overnight in hopes of tightening them up. When I have had the HE,s leak at the head, the only way it got them to stop was to remove the muffler, but leave on bolt holding the weight at the rear bracket. Then I tighten up the heat exchangers... After tight, I install the muffler again. Rich |
| kmwvmarip |
May 17 2014, 08:54 PM
Karl M. ![]() ![]() Group: Members Posts: 74 Joined: 9-April 12 From: Mariposa, California Member No.: 14,354 Region Association: Central California |
I too recently took off the Heat exchangers and I had a stud come out. I suppose I would just double up on the nut and screw it back in again, right? Anything else to do while I am there?
Noob question prolly, but thanks in advance. |
| ClayPerrine |
May 17 2014, 10:13 PM
Life's been good to me so far..... ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 16,542 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille
Replace the copper gaskets that go between the heads and the heat exchangers. Be careful not to over tighten the nuts on the studs. It can cause the ears on the heat exchangers to bend, and pulled studs for the exhaust.
Remember, everything on these engines tightens up when they get hot. Oh.. and be careful putting a stud back in the head. It is easy to over torque them and rip the threads out of the head. |
| messix |
May 18 2014, 02:41 AM
AKA "CLUTCH KILLER"! ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,995 Joined: 14-April 05 From: between shit kickers and pinky lifters/ puget sound wa.north of Seattle south of Canada Member No.: 3,931 Region Association: Pacific Northwest |
| Allan |
May 18 2014, 05:46 AM
Teenerless Weenie ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,373 Joined: 5-July 04 From: Western Mesopotamia Member No.: 2,304 Region Association: Southern California |
(IMG:style_emoticons/default/agree.gif) I screwed up the ears on my new to me ss exchangers using a 3/8" ratchet. |
| ripper911 |
May 18 2014, 02:30 PM
(IMG:style_emoticons/default/mad.gif) I know what by it's so loud now...
My right side exchanger is only held on by one nut! the muffler end is missing nuts too. You can guess who worked on it last. |
| Larmo63 |
May 18 2014, 02:37 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,267 Joined: 3-March 14 From: San Clemente, Ca Member No.: 17,068 Region Association: Southern California |
My car is backfiring on deceleration, not to hijack the thread, but could it be that I have loose HE's? It started when I put the stock muffler on....
| r_towle |
May 18 2014, 02:49 PM
(IMG:style_emoticons/default/mad.gif) I know what by it's so loud now... My right side exchanger is only held on by one nut! the muffler end is missing nuts too. You can guess who worked on it last. Stop whining and go jack it up and fix it. Rich |
| ripper911 |
May 18 2014, 02:55 PM
It is jacked up... I don't have any nuts for it. Are the copper ones available from the flaps?
| r_towle |
May 18 2014, 03:08 PM
Just get normal nuts, they work fine
| ripper911 |
May 18 2014, 05:44 PM
Done and DONE! Sounds much better!
| ClayPerrine |
May 18 2014, 09:43 PM
There is a Mercedes nut used on their exhaust manifolds that work great on the 914 heat exchangers. They are treated so they don't seize to the studs, and they have a flange that fits the heat exchanger really well.
And for the muffler, use longer bolts and double nut them. The bolts won't back out that way, and you don't have to worry about pulled head studs because the bolt holding the muffler to the boomerang fell out. |
| stugray |
May 18 2014, 10:42 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,825 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None |
You can get a 8mm thread nut that takes a 12mm wrench instead of a 13mm.
Called a JIS nut https://www.belmetric.com/metric-nuts-jis-s...CFceCfgodqSwA4A It makes it easier to get a socket on with the smaller nut |
| malcolm2 |
May 19 2014, 07:04 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,749 Joined: 31-May 11 From: Nashville Member No.: 13,139 Region Association: South East States
Replace the copper gaskets that go between the heads and the heat exchangers. It is a whole 'nother topic, but I think I remember that a lot of participants on this forum anneal the copper washers first. Am I remembering correctly? Get out the torch and heat the washer to red hot. Let it cool in the air, then install. I barely made it out of metallurgy (30 years ago) so I would not consider myself very knowledgeable of all the microscopic reasons. But I do remember that the tuning fork feature of a heated washer went away vs. a non heated one. |
| malcolm2 |
May 19 2014, 07:07 AM
You can get a 8mm thread nut that takes a 12mm wrench instead of a 13mm. Called a JIS nut https://www.belmetric.com/metric-nuts-jis-s...CFceCfgodqSwA4A It makes it easier to get a socket on with the smaller nut I like the theory. That link did not have copper. I suppose there are lots of cars out there without copper nuts on the exhaust. |
| Larmo63 |
Are these copper washers available?
| stugray |
May 19 2014, 07:26 AM
QUOTE Are these copper washers available? I think there is some confusion above. The copper "washers" are the gaskets, and yes they should be annealed with a torch before use. http://www.pelicanparts.com/catalog/SuperC...P_pg1.htm#item2 |
Lo-Fi Version | Time is now: 16th April 2026 - 01:19 PM |
