door dome light switch question, light does not come on, what do i check first??? |
DRPHIL914 |
May 19 2014, 07:27 AM
Dr. Phil Group: Members Posts: 5,768 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States |
wondering if this is a bad switch, just bad connection? light works when switch at the light is changed to the on position
JawjaPorsche |
May 19 2014, 07:33 AM
Advanced Member Group: Members Posts: 3,463 Joined: 23-July 11 From: Clayton, Georgia Member No.: 13,351 Region Association: South East States |
It it the original light?
The newer cheaper ones only work with the switch because it came only with two connections instead of three that came with original light? |
DRPHIL914 |
May 19 2014, 10:03 AM
It it the original light? The newer cheaper ones only work with the switch because it came only with two connections instead of three that came with original light? the one i have is not original, that was broken and has been discarded- i did not know at the time they were rare- but the one i have does have the 3 connectors, yes |
sfrenck |
May 19 2014, 10:36 AM
Member Group: Members Posts: 492 Joined: 28-February 10 From: Wilmington, DE Member No.: 11,411 Region Association: MidAtlantic Region |
Door switch isn't making a "ground" connection. The spring loaded switch has a couple of pointed pieces of copper that touch the chassis when the door opens - if there is rust at the points where they touch the circuit won't complete. I scratched the rust off the inside somehow (can't remember - curved dental pick maybe) and it fixed the issue.
Lo-Fi Version | Time is now: 11th June 2024 - 12:34 PM |
