I need short manifolds for a pair of IDF's |
agrump |
Jan 17 2005, 07:43 PM
Member Group: Members Posts: 141 Joined: 13-November 04 From: Atlanta, GA Member No.: 3,103 |
Anyone know where I can get them?
Thanks |
URY914 |
Jan 17 2005, 08:34 PM
I built the lightest 914 in the history of mankind. Group: Members Posts: 121,070 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
Can you cut the top (carb) flange off, cut a section out and weld the flange back on??
Just wondering? I've heard the short ones are hard to find and I need some too. Paul |
Aaron Cox |
Jan 17 2005, 08:43 PM
Professional Lawn Dart Group: Retired Admin Posts: 24,541 Joined: 1-February 03 From: OC Member No.: 219 Region Association: Southern California |
whats great about the short ones?
taller = more torque right? |
r_towle |
Jan 17 2005, 08:45 PM
Custom Member Group: Members Posts: 24,591 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
I have a few, what do you mean by short??
Rich |
scooter311 |
Jan 17 2005, 08:59 PM
Member Group: Members Posts: 231 Joined: 22-October 04 From: Upstate NY Member No.: 2,986 |
Heya I just got rid of a set of shortys - I hated them, it was a nighmare trying to change plugs, wires, etc. I traded a dood for a tall set a short while ago. I would've paid you to take them, I hated them so much (IMG:http://www.914world.com/bbs2/html/emoticons/ar15.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/ar15.gif)
URY914 |
Jan 17 2005, 09:26 PM
Well, Jake told me to get short ones soooooo, I'm looking for short ones 'neff said. (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) |
cha914 |
Jan 17 2005, 09:54 PM
MUSR 8 - 5lug conversion done wed - drive 500miles thrus Group: Members Posts: 739 Joined: 31-December 02 From: Austin, TX Member No.: 63 |
hmm...I like welding alum...just got a new bandsaw....sounds like fun (IMG:http://www.914world.com/bbs2/html/emoticons/tongue.gif)
r_towle |
Jan 17 2005, 09:56 PM
so, how short do you need them, I have a few sets here of differing lengths.
Rich |
Jake Raby |
Jan 17 2005, 10:04 PM
Engine Surgeon Group: Members Posts: 9,394 Joined: 31-August 03 From: Lost Member No.: 1,095 Region Association: South East States |
Its all dependant upon the combo!
Efficient engines like a shorter manifold to produce the best results in the upper RPM range. Intake length is just part of the overall runner length, combined with the velocity stack length as well.. The stacks and the manifolds must be chosen for the engine to make its most.. Thats why I have a dyno and every manifold and stack known to man. Every new combo gets tested with all them to see which ones give the best curves. |
r_towle |
Jan 17 2005, 10:40 PM
Again, in response to YOUR question... And the previous question, how short would you like to get. I have, on my shelf several different length setups. I am aware that each engine has differing needs, that was not the question here... The question is where to get the manifolds. I have some, what size are you needin? Rich |
ChrisFoley |
Jan 18 2005, 05:35 AM
I am Tangerine Racing Group: Members Posts: 7,934 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
I built a fixture to do just that! Specifically - I can shorten the standard IDF manifolds from 5 1/4" to 4 " runner length, which is the same as the standard Solex manifolds. |
DJsRepS |
Jan 18 2005, 05:59 AM
Member Group: Members Posts: 431 Joined: 4-November 04 From: Sarasota Florida Member No.: 3,060 |
When I grow up Im getting me a motor by Jake! with one of his side shift 4speed. No need for 1st gear of a 5 speed with his dyno proven hp and rpm.
Walter |
Jan 18 2005, 06:06 AM
Member Group: Members Posts: 70 Joined: 10-August 04 From: The Netherlands, Europe Member No.: 2,499 |
I really don't have assets in that company, but Ahnendorp makes rather short manifolds, compared to the CB ones, both for 4-bolt and 3-bolt. Not one size fits all. And the 40IDF manifold has a 40mm opening, the 44IDF/45DLRA manifold has 45mm opening, not 48mm for all carbs as I've seen a lot.
Also, those manifolds let you mount your carb either way around (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) Regards, Walter |
Joe Ricard |
Jan 18 2005, 07:18 AM
CUMONIWANNARACEU Group: Members Posts: 6,811 Joined: 5-January 03 From: Gautier, MS Member No.: 92 |
Wish I had a dyno (IMG:http://www.914world.com/bbs2/html/emoticons/sad.gif)
agrump |
Jan 18 2005, 07:52 AM
Oh I hope I don't get lambasted for this. I need short manifolds so that I can use a pair of air cleaners from a 356/912. The purpose of it is to cut down on intake noise. I need at least an inch more clearance, 1-1/2” would be better. My current manifolds are the standard tall ones that come with your usual carb kits. 5 ¼” sounds about right so a 4” or less manifold would work for me.
I have not considered what effect this will have on performance. My engine is not that highly tuned from what I can tell from the paperwork I got when I bought the car. It’s a 2.0L euro pistons with a .03” spacer, FAT FC442 cam and 2.0L heads. I’m guessing the compression ratio is 7.5:1. |
maf914 |
Jan 18 2005, 07:53 AM
Not a Guru! Group: Members Posts: 3,049 Joined: 30-April 03 From: Central Florida Member No.: 632 Region Association: None |
I bought a pair of short manifolds, shorter than the typical CB Performance manifold for 2-barrel IDF's, from PMO several years ago. They may still offer these.
ChrisFoley |
Jan 18 2005, 09:07 AM
The PMO manifolds are 5 1/4" runner length. They are available properly sized for 40 or 44 IDF carbs. Attached image(s) |
Jake Raby |
Jan 18 2005, 09:22 AM
The intake noise probably won't drop much with the addition of the 356 air filters.... Many times the intake note is a by- product of the camshaft choice as well as the headwork. Alot of engines that have huge intake valves have this trait and it really can't be remedied.
The FAT cam you mention is notorious for this trait. Its almost as bad as the Web 494 |
agrump |
Jan 18 2005, 11:01 AM
Ugh, that’s bad news; I was hoping that it would make a significant impact on the noise level. I don’t believe there has been any headwork besides a new set of stock valves/seats. I’ll still try it but when it doesn’t work I’ll consider splitting the block to change the cam and maybe bumping up the displacement. A cam change may be a good thing as I’m happy with the power but the mpg is lower then I would expect. I’m also planning on addressing the mpg problem by controlling timing with a megasquirt unit. I have all the pieces lying around so I might as well use them.
Racer Chris, how much would you charge to chop and weld a set of manifolds? Would it be more trouble to take out another ¼ inch? I have a spare set of Scat manifolds that look similar to the one shown except it has more webbing between the two ports. |
Walter |
Jan 18 2005, 11:54 AM
FYI, intake noise is greatly reduced with a central intake airfilter system. Not cheap tho..
Greetings, Walter |
Lo-Fi Version | Time is now: 9th June 2024 - 08:02 PM |
