| Dave_Darling |
Jun 22 2014, 10:21 PM
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,338 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California
Here are the questions from the 914 section of the 2014 Parade tech quiz. Several of the questions appear to have been written by "real" 914 folks; see for instance Q 53 answer a. (IMG:style_emoticons/default/smile.gif)
There are a few answers that are debatable, according to your point of view as well. The questions I got wrong were: 55, 67, 69. I actually got 67 right, but the official answer was wrong. (That question was successfully protested and thrown out.) - - - - - - - - - 51) The 914-4 is known internally (at the VW factory) as the a) peoples’ car; b) Karmann; c) VW-Porsche; d) VW Type 47. 52) Pop-up headlights were used on the 914 a) in order to comply with U.S. lighting-height law; b) to give sleeker appearance when not in use; c) as an attempt to keep them cleaner; d) to develop the concept for the future 924. 53) What is the approximate fuel pressure at the injectors of the D-Jetronic system? a) Enough for a leak b) 75 psi c) 10 psi d) 30 psi 54) Both the 914-4 and 914-6 used a hand throttle. a) True b) False 55) A 914-6 was used as a pace car for the 1971 Daytona 500. a) True b) False 56) For the 1974 model year American market the base engine was a 1.8 liter with a) D-Jetronic fuel injection; b) L-Jetronic fuel injection; c) K-Jetronic fuel injection; d) Motronic fuel injection. 57) The 914 used the same 901 gear box as the 911 but turned end for end. Because of the __________. a) the ring gear had to be mounted opposite of the 911 location. b) it required a reverse rotation throwout bearing c) all the gears had to be flipped end for end d) the engine rotation was reversed 58) The front suspension on the 914 is a) unequal length A arm; b) coil spring concentric with shock; c) torsion bars with McPherson struts and lower wishbones. d) torsion bar concentric with shock; 59) The 914 1.8 liter camshaft is driven by _________ a) timing chain b) toothed belt c) gears d) pure luck 60) The 1.7 and 1.8 liter engines do not share the same crankshaft. a) True b) False 61) The windshield wiper switch on a 1970 914-4 was located a) The switch was made by Lucas and never worked, so it doesn’t matter where it was. b) on the steering column. c) on the dash d) on the center console 62) The brake lights are activated by a hydraulic switch. a) True b) False 63) A shortcoming of the early 914’s was the shift linkage. The improved version came in 1973. a) True b) False 64) What tool is needed to remove the tail light lenses on the 914? a) Fingers b) Phillips screwdriver c) Straight tip screwdriver d) 10mm wrench 65) The engine of the 914/6 was the same as used in the 1970 911T. a) True b) False 66) All 914 bodies were built by a) Reutter b) Porsche c) Karmann d) VW 67) The production 914-4 and 914-6 cars for the U.S. market had the “Porsche” crest on the hood. a) True b) False 68) In 1973 the method for wheel centering was changed from _______. a) bolt centric to hub centric b) hub centric to bolt centric c) orbitally to closed cone method d) variable to definite 69) The firing order of the 914/6 engine is ______. a) 18436572 b) 146325 c) 164235 d) 162435 70) The hoses on 1973 914 2.0 fuel injection unit are color coded. The brown hoses are related to the ____________. a) deceleration valve b) windscreen washer c) distributor d) EGR valve 71) The vapor lock problem on 914-4’s was alleviated when Porsche moved the fuel pump to the front of the car. a) True b) False 72) The 914-6 option package M471 included ______________. a) flared fenders. b) flared rocker panels. c) flared front valance. d) all of the above 73) For 1970 and 71 leather trim was only available on six-cylinder models. a) True b) False 74) The problems with the shaft and bushings which support the brake and clutch pedal assembly could cause _______________. a) dragging brakes b) overheated brakes c) inconsistent pedal height d) all of the above 75) On a 914 1.8 there are two electric boxes attached to the underside of the battery tray. One is the J40 double relay and the other is a resistor package that provides reduced voltage from the battery to the __________. a) interior light b) tachometer c) brake lights d) fuel injectors |
| ConeDodger |
Jun 22 2014, 11:51 PM
Apex killer! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,426 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California
Pure luck crankshaft drive... What a novel idea that was! (IMG:style_emoticons/default/blink.gif)
| barefoot |
Jun 23 2014, 06:55 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,507 Joined: 19-March 13 From: Charleston SC Member No.: 15,673 Region Association: South East States
where are answers posted ??
| GeorgeRud |
Jun 23 2014, 08:34 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,725 Joined: 27-July 05 From: Chicagoland Member No.: 4,482 Region Association: Upper MidWest |
They actually managed to have some printing/collating issues so some folks got handed the answer sheets rather than the test sheets!
There were a few events where a bit more planning could have been better planned. At the welcome party, they had four bars set up for the crowd (over 1400 people), so the lines were rediciously long. However, it was still a great time, and a record setting number of cars that participated. Now we have to wait for the next Rennfest Reunion to have another excuse to visit Monterey! |
| Dave_Darling |
Jun 23 2014, 11:05 AM
where are answers posted ?? They aren't. (IMG:style_emoticons/default/biggrin.gif) I'll post them up in a few more days. --DD |
| SLITS |
Jun 23 2014, 11:26 AM
"This Utah shit is HARSH!" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None |
| JeffBowlsby |
Jun 23 2014, 01:19 PM
914 Wiring Harnesses & Beekeeper ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,247 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None
Those are tough questions Dave...Congrats to you!
| Dave_Darling |
Jun 24 2014, 11:41 AM
Answers here:
1) The 914-4 is known internally (at the VW factory) as the d) VW Type 47. 52) Pop-up headlights were used on the 914 a) in order to comply with U.S. lighting-height law; 53) What is the approximate fuel pressure at the injectors of the D-Jetronic system? d) 30 psi 54) Both the 914-4 and 914-6 used a hand throttle. b) False 55) A 914-6 was used as a pace car for the 1971 Daytona 500. a) True 56) For the 1974 model year American market the base engine was a 1.8 liter with b) L-Jetronic fuel injection; 57) The 914 used the same 901 gear box as the 911 but turned end for end. Because of the __________. a) the ring gear had to be mounted opposite of the 911 location. 58) The front suspension on the 914 is c) torsion bars with McPherson struts and lower wishbones. 59) The 914 1.8 liter camshaft is driven by _________ c) gears 60) The 1.7 and 1.8 liter engines do not share the same crankshaft. b) False 61) The windshield wiper switch on a 1970 914-4 was located c) on the dash 62) The brake lights are activated by a hydraulic switch. b) False 63) A shortcoming of the early 914’s was the shift linkage. The improved version came in 1973. a) True 64) What tool is needed to remove the tail light lenses on the 914? a) Fingers 65) The engine of the 914/6 was the same as used in the 1970 911T. b) False 66) All 914 bodies were built by c) Karmann 67) The production 914-4 and 914-6 cars for the U.S. market had the “Porsche” crest on the hood. b) False 68) In 1973 the method for wheel centering was changed from _______. a) bolt centric to hub centric 69) The firing order of the 914/6 engine is ______. d) 162435 70) The hoses on 1973 914 2.0 fuel injection unit are color coded. The brown hoses are related to the ____________. a) deceleration valve 71) The vapor lock problem on 914-4’s was alleviated when Porsche moved the fuel pump to the front of the car. a) True 72) The 914-6 option package M471 included ______________. d) all of the above 73) For 1970 and 71 leather trim was only available on six-cylinder models. a) True 74) The problems with the shaft and bushings which support the brake and clutch pedal assembly could cause _______________. d) all of the above 75) On a 914 1.8 there are two electric boxes attached to the underside of the battery tray. One is the J40 double relay and the other is a resistor package that provides reduced voltage from the battery to the __________. d) fuel injectors |
| Dave_Darling |
Jun 24 2014, 11:44 AM
| Cap'n Krusty |
Jun 24 2014, 02:19 PM
Cap'n Krusty ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,794 Joined: 24-June 04 From: Santa Maria, CA Member No.: 2,246 Region Association: Central California |
I coulda been the winner!
The Cap'n |
| Dave_Darling |
Jun 24 2014, 02:34 PM
It's a lot easier here than sitting in a room with fifty or so other people, at oh-ghod-hundred in the AM, with no breakfast and NO COFFEE! Not to mention that the tests got pretty screwed up...
--DD |
| SLITS |
Jun 24 2014, 02:43 PM
d,a,d,b,a,b,a,c,c,b,c,b,a,a,b,c,b,a,d,a,a,d,a,d,d d,a,d,b,a,b,d,c,c,b,c,b,a,a,a,c,b,a,d,a,a,d,a,c,d. I think I count three wrong. --DD Correct .... The M whatever package The 1970 T engine The brake/clutch assembly I feel so ignorant! (IMG:style_emoticons/default/sad.gif) |
| TheCabinetmaker |
Jun 24 2014, 02:56 PM
I drive my car everyday ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,377 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
I only missed #69 cause I had no idea. Never worked on a six.
| JeffBowlsby |
Jun 24 2014, 03:03 PM
I think we should start a thread and generate our own questions/answers for the next parade. (IMG:style_emoticons/default/wink.gif)
| ConeDodger |
Jun 24 2014, 03:40 PM
Class: Q06M
Region 914 1 107 5 0592A Darling David Loma Prieta (38, 23) 2 102 4 0291A Blyholder Andrew Golden Gate (33, 23) 3 98 4 0274A Rudawsky George Chicago (35, 21) 4 93 4 0858A Spreen Carey Maverick (39, 18) 5 84 5 0297A Kust Paul Oregon (33, 17) 6 83 4 0822A Howard Travis Maverick (26, 19) 7 83 2 0092A Koozmin Mike Loma Prieta (32, 17) 8 82 4 0446A Checel Lester Northern Ohio (31, 17) 9 77 4 0061A Biddle Robert Arizona So, I didn't see an overall winner. Were the tests all model specific? |
| Krieger |
Jun 24 2014, 04:00 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,855 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None
E. All of the above.
| Krieger |
Jun 24 2014, 04:01 PM
Good job Dave (IMG:style_emoticons/default/first.gif)
| Dave_Darling |
Jun 24 2014, 05:16 PM
So, I didn't see an overall winner. Were the tests all model specific? All tests had 50 general questions, 25 model-specific questions, and 5 tie-breaker questions. Scores for the model-specific awards are calculated by (generals + 3*model-specific), and ties broken by tie-breakers. Scores for the overall awards are calculated by (3*generals + model-specific), again with ties broken by tie-breakers. The overall winner was Manny Alban, who also happens to be the current president of PCA... (IMG:style_emoticons/default/biggrin.gif) Interestingly enough, nobody got more model-specific questions right than I did--and Andrew Blyholder, another 914'er, was the only one to get just as many right as I did! --DD |
| dlkawashima |
Jun 24 2014, 06:53 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,749 Joined: 1-October 10 From: San Jose Member No.: 12,234 Region Association: Northern California |
I guess I don't understand how the scoring goes, but you had 107 points and Manny Alban had 103. Doesn't that make you the winner?
| theleschyouknow |
Jun 24 2014, 07:09 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 524 Joined: 4-June 13 From: Texas Member No.: 15,967 Region Association: None |
I guess I don't understand how the scoring goes, but you had 107 points and Manny Alban had 103. Doesn't that make you the winner? me neither but if I'm reading right dbl d took model specific 107-102 shouldn't he have also taken overall 137 - 122? great job either way trophies are for whiners |
Lo-Fi Version | Time is now: 2nd May 2026 - 12:13 PM |
