> Brake light relay, won't stop blinking
ben*james
post Jul 3 2014, 05:43 PM
LIFER
Seems to be getting worse and worse. Brake lever fully depressed. Pretty sure it's hitting the little button. After a few miles and bumps I have to pull over and set then release the break to stop the blink. I'm thinking about cutting the wires but I should probably fix it correctly (IMG:style_emoticons/default/smile.gif)
Spoke
post Jul 3 2014, 05:51 PM
Jerry
Sounds like you need a bit of an adjustment.
I had to glue a little piece of plastic to the handle to fully depress the switch.
toolguy
post Jul 3 2014, 07:04 PM
1 screw and it pulls out. . then look at the contacts. . new ones are available at the dealer . same part as the door light switch . it's now a 944 part number but works fine. .
- Lo-Fi Version Time is now: 16th April 2026 - 05:50 PM
