What size spacer do I need?, Getting tire rub against wheel well metal |
tumamilhem |
Aug 27 2014, 05:01 PM
LUFTBRIGADE Group: Members Posts: 1,228 Joined: 29-October 12 From: Jacksonville, FL Member No.: 15,092 Region Association: South East States |
Not sure what thickness spacers I need for my front wheels. Tire has worn away the paint. My mechanic suggested 1/4" thick spacers, but I wonder if that's enough. Suggestions?
I have stock 4 lug Mahle wheels with 205/60 R15 size tires. It keeps uploading sideways for some reason. But you can see how much is worn. |
Elliot Cannon |
Aug 27 2014, 10:10 PM
914 Guru Group: Retired Members Posts: 8,487 Joined: 29-December 06 From: Paso Robles Ca. (Central coast) Member No.: 7,407 Region Association: None |
Try 8mm or 1/4 in spacer. Put some paint were it is rubbing and see if it rubs the paint off. If it does, try a wider spacer. (IMG:style_emoticons/default/biggrin.gif)
bulitt |
Aug 28 2014, 02:24 AM
Achtzylinder Group: Members Posts: 4,188 Joined: 2-October 11 Member No.: 13,632 Region Association: South East States |
Get a stack of large washers and pile them up until you have clearance, then measure the washers.
Lo-Fi Version | Time is now: 23rd May 2024 - 01:43 PM |
