| mikey |
Jan 31 2005, 02:20 AM
Member ![]() ![]() Group: Members Posts: 425 Joined: 30-January 03 From: San Francisco Member No.: 214 Region Association: None |
Does anyone have a picture of a 914-6 fuse panel they could post? I'm re-installing mine after replacing the harness and new style fuse block. I've got 4 relays (3 round ones and 1 square one) and 4 mounting holes on the fuse panel. But I'm not sure which relay goes in which hole. My manual only shows a 914-4 fuse panel.
| propricer |
Jan 31 2005, 09:58 AM
Member ![]() ![]() Group: Members Posts: 365 Joined: 16-April 04 From: Morgan Hill, CA Member No.: 1,938 |
Will try to get pix and / or info by tomorrow.
Ed - down south in Morgan Hill |
| mikey |
Jan 31 2005, 10:46 AM
Thanks Ed! (IMG:http://www.914world.com/bbs2/html/emoticons/smilie_pokal.gif)
| Gustl |
Jan 31 2005, 11:30 AM
914 enthusiast & historian ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,084 Joined: 16-June 04 From: TIROL / Austria Member No.: 2,212 Region Association: Austria |
not sure if this helps, this is out from the factory repair manual:
914-4 A - low beam B - fresh air blower C - additional high beam D - buzzer (I hope my translation is correct (IMG:http://www.914world.com/bbs2/html/emoticons/rolleyes.gif) ) Attached thumbnail(s)
| Gustl |
Jan 31 2005, 11:33 AM
914-6:
A - buzzer B - fog lamps C - horn Attached thumbnail(s)
| Gustl |
Jan 31 2005, 11:35 AM
I added both types because you wrote about 3 round and 1 square relays - and this is shown only at the -4 board (IMG:http://www.914world.com/bbs2/html/emoticons/huh.gif)
| mikey |
Jan 31 2005, 12:06 PM
Thanks Wolfgang! Hmmm, I think I'm more confused than before. (IMG:http://www.914world.com/bbs2/html/emoticons/unsure.gif) |
| propricer |
Feb 1 2005, 10:22 AM
I'm assuming that Wolfgang has answered your question as well as I could.
If it would help to SEE one, take a drive south. ... Ed |
| mikey |
Feb 1 2005, 01:25 PM
Ed,
I'll be passing through Morgan Hill on the way to Long Beach this weekend. How does Saturday mid-morning sound? PM me with details if this sounds doable. The picture Wolfgang sent agrees with what I saw on a local 914-6 yesterday. However, I have an extra square relay (?) that I don't know where to mount. Thanks, Mike |
| sixnotfour |
Feb 1 2005, 02:37 PM
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,184 Joined: 12-September 04 Member No.: 2,744 Region Association: NineFourteenerVille
The Diagram I have that matched your ignition Question, shows ;
1 addtional headlight relay . 2 headlamp flasher. 3 horn relay, 4 square turn indicator and hazard warnig flasher unit Will it go in location D in Wolfgangs 6 pic.? Hpoe this Helps , Jeff (IMG:http://www.914world.com/bbs2/html/emoticons/burnout.gif) |
Lo-Fi Version | Time is now: 2nd April 2026 - 10:00 AM |
