1971 no horn need help, Electrical help |
mr2by4 |
Nov 15 2014, 01:38 PM
Member Group: Members Posts: 182 Joined: 9-December 07 From: Fort Worth Member No.: 8,439 Region Association: Southwest Region |
I seem to be missing a wire of some sort or a connection. With the wheel mounted I can't make any connection. Here is what is under the wheel in my 71. Am I missing something or am I just not making a good connection between the ring and the electrical pick up?
Attached thumbnail(s) |
mepstein |
Nov 15 2014, 02:37 PM
914-6 GT in waiting Group: Members Posts: 19,313 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Do you have the horn plunger in the steering wheel?
mr2by4 |
Nov 15 2014, 03:50 PM
Cap'n Krusty |
Nov 15 2014, 04:40 PM
Looks like you have an early car and a late wheel.
The Cap'n |
mepstein |
Nov 15 2014, 06:33 PM
Definitely a late horn pad.
bandjoey |
Nov 15 2014, 06:42 PM
bandjoey Group: Members Posts: 4,926 Joined: 26-September 07 From: Bedford Tx Member No.: 8,156 Region Association: Southwest Region |
Might need to do a wheel swap. See the parts diagram at pelican parts it's a spring loaded plunger that goes through a hole in the wheel and contacts the metal plate under the wheel.
mr2by4 |
Nov 15 2014, 09:31 PM
How can a late wheel fit? I thought that they were incompatible and required different hubs to mount an aftermarket wheel?
Can I just get a Momo with a horn button and be done? is 914-347-832-01-OEM, the "73mm horn contact button" what I need? |
mepstein |
Nov 15 2014, 09:51 PM
How can a late wheel fit? I thought that they were incompatible and required different hubs to mount an aftermarket wheel? Can I just get a Momo with a horn button and be done? is 914-347-832-01-OEM, the "73mm horn contact button" what I need? I don't have a horn contact button that you need but I have the other parts to make your horn work. Free + shipping. Looking closer at the pics, you have the correct early wheel and early hub. You just need the parts from an early horn pad, the one you have Is for the later wheel that uses a wire instead of the horn contact pin. |
mepstein |
Nov 15 2014, 09:55 PM
mr2by4 |
Nov 15 2014, 09:58 PM
How can a late wheel fit? I thought that they were incompatible and required different hubs to mount an aftermarket wheel? Can I just get a Momo with a horn button and be done? is 914-347-832-01-OEM, the "73mm horn contact button" what I need? Yes. Looks Like I will be placing an order Monday. I should probably make a list to save on shipping and time. Sounds like an excuse to spend Sunday afternoon browsing for other things to add on.... |
mr2by4 |
Nov 17 2014, 05:52 AM
So it looks like I need an early horn pad.
Is there a way to make my late pad work by modifying it? I assume that this is NLA from Porsche, any vendor jumped on this bandwagon? Would this get me what I need? http://www.914world.com/bbs2/index.php?showtopic=244526 Do I still need a horn plunger with that wheel? Sorry to he so helpless on this, but since I don't have the parts I need, I can't look at them to see how they work and figure out a way to make mine work. Do I need a metal contact in my late button to make the early plunger work? Could that be made? Will these work with my pad? http://www.914world.com/bbs2/index.php?showtopic=243399 I am mostly questions at this point. Thanks for supplying answers! |
mr2by4 |
Nov 17 2014, 04:53 PM
Looks like Mepstein has me covered.
THANKS! |
mr2by4 |
Nov 26 2014, 05:53 PM
mepstein |
Nov 26 2014, 08:11 PM
The top of the horn plunger runs against the flat metal bracket instead of using a wire to make the connection to the tab on the plate.
mr2by4 |
Nov 26 2014, 09:27 PM
The top of the horn plunger runs against the flat metal bracket instead of using a wire to make the connection to the tab on the plate. It does not touch the bracket. It pokes into the center, where there is a hole. Is that plate supposed to be grounded in some way so that when the plunger contacts it the circuit is completed? The parts diagram on Pelican is too small/lacks the detail to help me out. |
mepstein |
Nov 26 2014, 09:34 PM
It should go in the hole on the right hand side of the hub, not the center. It's the only hole on the metal bracket on the face of the hub.
The bottom of the horn plunger will run against the metal disc on the steering column. As shown in your first pic |
mr2by4 |
Nov 26 2014, 09:40 PM
It should go in the hole on the right hand side of the hub, not the center. It's the only hole on the metal bracket on the face of the hub. The bottom of the horn plunger will run against the metal disc on the steering column. As shown in your first pic That explains much! Thanks the exploded parts view just showed everything exploded. I will try to sneak by and try that tomorrow! (IMG:style_emoticons/default/dry.gif) |
mr2by4 |
Nov 27 2014, 09:51 PM
I got the plunger in today and that makes much more sense, but still no honking. So I pulled off the pad, pulled off the wheel and looked for current. I thought that the ring was hot when I checked this before, but now it all seems dead.
My next step is to pull out the Haynes and start tracing the wire back. Do I understand correctly that on the 71' there is no relay but the horn ring is really hot and in the circuit to the horns? Any suggestion for common places to look for a fault? All my fuses look good in the dash and also in the engine bay. gratuitous picture of correctly installed plunger. |
mepstein |
Nov 27 2014, 10:15 PM
maybe try shorting the horn to make sure it works.
mr2by4 |
Nov 28 2014, 11:01 AM
maybe try shorting the horn to make sure it works. Don't I need to pull the bumper to get at horns? If there is no power at the wheel, that would seem to be a bigger problem. I can go either direction on this one. I thought that it might be easier to start at the source, rather than the destination. |
Lo-Fi Version | Time is now: 8th June 2024 - 06:38 AM |
