rear calipers, What other Porsches have the same |
morph |
Feb 1 2005, 06:16 PM
quality parts builder Group: Members Posts: 1,828 Joined: 25-November 03 From: oregon coast Member No.: 1,389 Region Association: Pacific Northwest |
do any other models share the same rear calipers?
james (IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif) |
JFJ914 |
Feb 1 2005, 06:17 PM
Senior Member Group: Benefactors Posts: 813 Joined: 13-June 03 From: Alpharetta, GA Member No.: 814 Region Association: South East States |
No.
morph |
Feb 1 2005, 06:21 PM
thanks just the awnser i was looking for.next question was there diffrent sizes in them ?was there a larger and a smaller model ?for the rear caliper?
james |
Eric_Shea |
Feb 1 2005, 06:28 PM
PMB Performance Group: Admin Posts: 19,278 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
No.
Unless you're talking 6 vs 4. They were the same physical size. The -6 pistons are bigger. TIP: If you want to rebuild -6 rears buy the 914-4 rebuild kit (with the caliper 1/2 seals and the adjuster seals) and then get the early 911T rear kits for the piston seals. |
drgchapman |
Feb 1 2005, 06:29 PM
Current Stable Group: NoClassifiedAccess Posts: 922 Joined: 20-September 04 From: Portland, OR Member No.: 2,789 Region Association: Pacific Northwest |
The only difference is whether the are single or double bleeders. The doubles were on the later models.
jwalters |
Feb 1 2005, 06:30 PM
Sooo Close....... Group: Members Posts: 1,677 Joined: 14-May 04 From: Huntsville, AL Member No.: 2,068 Region Association: Europe |
Who made them? Girling, ATE, etc..???
Eric_Shea |
ATE
Mueller |
Feb 1 2005, 06:36 PM
James....
not sure what you are after, but I was going to be attempting to test fit a modern OEM rear caliper that has a built-in parking brake similar to the 914. plus = aluminum, readily available negative = will require a custom mounting bracket (no big deal for some (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) ) |
d914 |
Feb 1 2005, 06:50 PM
Advanced Member Group: Members Posts: 2,331 Joined: 12-July 03 From: Atlanta, ga Member No.: 904 Region Association: South East States |
5 bolt pattern, vented disks, carrera rears , minor spacer washers to work, boxster with adapters and vented disks, ????
Joe Bob |
Feb 1 2005, 07:11 PM
Retired admin, banned a few times Group: Members Posts: 17,427 Joined: 24-December 02 From: Boulder CO Member No.: 5 Region Association: None |
Wasn;t the 914/6 rear caliper also used on the Ferrari...um 308?
Eric_Shea |
Feb 1 2005, 07:13 PM
Yes. With spacers for a vented rotor.
davep |
Feb 1 2005, 07:48 PM
914 Historian Group: Benefactors Posts: 5,152 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada |
Actually, the 914/6 rear caliper is physically bigger than the 914/4 and uses larger pads. The 914/6 caliper is quite similar to the 911 rear caliper in size and the outer casting is the same. |
Lo-Fi Version | Time is now: 7th June 2024 - 11:40 PM |
