> Plasti Dip my 914
yeahmag
post Dec 1 2014, 04:40 PM
I'm hoping to plasti dip my car to make it all one color after my off at SOW while I save up for paint. Does anyone in SoCal have experience with this. It seems dipyourcar.com can't sell their kits here, so I'm stuck buying the stuff off CraigsList which I can only imagine is picked up across state lines somewhere. For example:
http://losangeles.craigslist.org/sgv/ptd/4783292533.html
post Dec 1 2014, 05:08 PM
I saw some SUV advertising that service in Temecula, CA. Pretty sure he was "area local".
colingreene
post Dec 1 2014, 06:49 PM
please do not do it.
yeahmag
post Dec 1 2014, 06:52 PM
It's gonna happen. My car looks like a frankenstein with my repair panels on it. How could it be worse aesthetically? A year or so down the line she'll get the paint job she deserves.
dudzy's914
post Dec 1 2014, 07:08 PM
The youngin'
i would say do it! did mine this fall, looks great.
yeahmag
post Dec 1 2014, 07:10 PM
Turns out you can order the spray cans... I have 8 cans of Koi Orange with the "glossifier" coming. I also got the better spray tips and the prep spray. There is a 25% sale right now!
matthepcat
post Dec 1 2014, 07:31 PM
Meat Popsicle
Do it. Just make sure you get a pretty nice paint gun. Make sure its not too cold or wet outside when you paint, and do all your prep work correctly.
I would suggest masking off windows to make clean up faster...as well as wheels, tires, exhaust, and your engine lid grill area.
If you can pull the hood and trunk lids and paint them in the vertical position, it comes out nicer.
JRust
post Dec 1 2014, 07:57 PM
QUOTE(yeahmag @ Dec 1 2014, 05:10 PM) *
Nice! Really thought about doing my quarters on my roller with them. Added the GT flares & they are primer grey. Look a little out of place with my orange car (IMG:style_emoticons/default/blink.gif)
dudzy's914
post Dec 1 2014, 08:33 PM
The youngin'
I would not reccomend the spray cans for anything larger than wheels, you will get stripping. It is fairly cheap to get into I did my car for under $200 shipped(without the gun)
matthepcat
post Dec 1 2014, 09:13 PM
Meat Popsicle
QUOTE(dudzy's914 @ Dec 1 2014, 06:33 PM) *
^^agree^^ Spray paint cans are not for large surfaces.
altitude411
post Dec 1 2014, 09:37 PM
I drove my 6 into a tree
this is how you paint a car, you don't need a stupid compressor or spray cans.... (IMG:style_emoticons/default/first.gif)
https://www.youtube.com/watch?v=qinZkdzOtCQ
r_towle
post Dec 1 2014, 09:43 PM
Custom Member
QUOTE(altitude411 @ Dec 1 2014, 10:37 PM) *
Scotty would drop down on his knees and faint after just one fender.....
altitude411
post Dec 1 2014, 09:47 PM
Blow, don't suck.... blow don't suck.... (IMG:style_emoticons/default/blink.gif)
7TPorsh
post Dec 2 2014, 10:52 AM
7T Porsh
Don't do it. That crap gets into every crevice and when you want it off you will never get it all.
Use a wrap...vinyl wrap...peels off easily. Make it all carbon fiber!
mr2by4
post Dec 2 2014, 11:19 AM
QUOTE(7TPorsh @ Dec 2 2014, 08:52 AM) *
I think that for the cost you can't do vinyl, but you are right. I have looked at several cars that had been detailed and still had bits of "dip" in crevices too small to clean effectively, but large enough to see. If you are stripping for a proper repaint later, it might be ok.
7TPorsh
post Dec 2 2014, 11:59 AM
7T Porsh
well you could roll it on...I did temporarily using rustoleum gloss black way back.
ruby914
post Dec 2 2014, 02:14 PM
I did mine for the winter.
I had a hard time spraying it on, with out it getting like silly string?
Well, not that bad but it seemed to cure at the gun tip. It became like little rubber feathers floating in the air as you spray they land in the painted area.
I went to a bigger gun tip. It helped but still could not do a clean job.
It is only a body condom (ribbed with bumps) for the winter rain.
For that, it is working well.
You will need a gallon. I used red with a bag of metallic and some black tent.
Alphaogre
post Dec 3 2014, 01:04 AM
Get the dipyourcar.com gun that they sell. It makes all the difference and is worth every penny once you start spraying. It's not too much money either. It has adapted nozzle and everything to spray the dip repeatedly. The stuff is a little thicker then paint, so it can clog and gum up regular sprayers easily.
Also, do at least 4 or 5 coats for the first tim, this will help to peel it off down the road if you so choose, and makes it easier to pull the trim and window sections too.
My brother has dipped his FX35 and his buddies cars, he changes the color every 4 to 6 months. It turned out good, most people think it's a wrap. Just remember to to the same processes and lay it down the same as you would paint, nice long even overlapped passes.
Valy
post Dec 3 2014, 02:35 AM
QUOTE(altitude411 @ Dec 1 2014, 07:37 PM) *
Only in Romania...
The car is a Dacia 1300 (Renault 12)
yeahmag
post Dec 3 2014, 09:26 AM
Kinda stuck there... They don't sell gallons in CA legally. I've ordered the special nozzle for the spray cans to give me the best possibility of a passable result.
https://www.dipyourcar.com/Dip-Nozzle-cat/
-Aaron
QUOTE(Alphaogre @ Dec 2 2014, 11:04 PM) *
- Lo-Fi Version Time is now: 2nd April 2026 - 05:58 PM
