> Suspension console measurement question
altitude411
post Dec 7 2014, 11:56 AM
I drove my 6 into a tree
Hey guys, I'm taking numbers on my six chassis to see how everything specs... I have a question about this measurement from the "hole" in the firewall to the hole in the suspension console pivot shaft .... what or where is the "hole" in the firewall this is in reference to? Is this on a 4 only? I have no hole that is 28.25'' from the console pivot shaft hole.
Jeff Hail
post Dec 7 2014, 12:13 PM
(IMG:style_emoticons/default/smile.gif) Third one down from the window ledge
altitude411
post Dec 7 2014, 12:37 PM
Thanks Jeff, so it's a measurement for the 4's.... what about a 6? Maybe a number from the suspension console pivot shaft hole to the engine mount bolt hole? Anyone have a number?
* PO did some (IMG:style_emoticons/default/welder.gif) on suspension console and I'm trying to establish if it is still within spec...
post Dec 7 2014, 01:29 PM
Resident German
That hole pictured (For the main wiring harness) is *not* in the center but instead offset quite a bit to the right.
It is not useful for the measurement in question ...
Jeffs9146
post Dec 7 2014, 01:49 PM
Ski Bum
I think they are talking about the small hole in the middle of the firewall. (IMG:style_emoticons/default/idea.gif)
altitude411
post Dec 7 2014, 02:03 PM
My six doesn't have that hole? (IMG:style_emoticons/default/confused24.gif) Would it be accurate to measure across the firewall (side to side) and divide that in half to establish a center point to triangulate to?
post Dec 7 2014, 02:14 PM
Resident German
QUOTE(altitude411 @ Dec 7 2014, 12:03 PM) *
I think the hole in question is all the way on top ...
altitude411
post Dec 7 2014, 02:21 PM
Tried that one as well.... numbers don't work there either? That's a 30'' + measurement.
I clipped this from a well known restoration thread and that's where I thought it was referring to as well Andy?
cary
post Dec 7 2014, 02:33 PM
Are the left and right numbers the same?
altitude411
post Dec 7 2014, 02:36 PM
I'm still trying to establish a correct reference point... but if I use the upper hole in the firewall (Andy's arrow) I'm 3/16'' out from one side to the other.
I'm just not certain about the hole being on center so I wanted to cross reference with what others had done.
- Lo-Fi Version Time is now: 2nd May 2026 - 01:20 PM
