NEED HELP!!!!!!, Rear Trunk Stuck |
Allan |
Feb 3 2005, 01:55 PM
Teenerless Weenie Group: Members Posts: 8,373 Joined: 5-July 04 From: Western Mesopotamia Member No.: 2,304 Region Association: Southern California |
I have a welder coming out later to weld a panel into the floor of the rear trunk and can't get it open. The lock turns and goes in and out but it wont unlatch. Any way other than cutting to get it open????????????
Thanks (IMG:http://www.914world.com/bbs2/html/emoticons/pray.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/pray.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/pray.gif) |
ClayPerrine |
Feb 3 2005, 02:00 PM
Life's been good to me so far..... Group: Admin Posts: 15,498 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
Open the engine compartment. Pop out one of the plastic inserts for the targa top latches. Then stick a long extension down the hole wth a 10MM socket and a wobble on the end. Unscrew the catch from the rear wall of the trunk.
You can also unbolt the hinge to make some room to work. |
Allan |
Feb 3 2005, 02:38 PM
Thanks a ton. Got it open!!!!!!! (IMG:http://www.914world.com/bbs2/html/emoticons/smilie_pokal.gif)
Lo-Fi Version | Time is now: 1st June 2024 - 01:05 AM |
