Clutch cable adjustment? |
Hank914 |
Jan 4 2015, 12:16 AM
Member Group: Members Posts: 389 Joined: 7-April 14 From: CA and OR Member No.: 17,215 Region Association: None |
I installed my new Dr Evil transmission but went to hook up the clutch cable and the clutch pedal doesn't come all the way up from the floor, it only comes about 80% up. And when I push it to the floor, it does not seem to disengage completely. Last time I installed my rebuilt (original) tranny, no adjustment to the cable was needed. Since this is a different core, are there adjustments to be made? Is it all adjustable at the end of the clutch cable?
Thanks for any help and all help for this semi-literate mechanic wannabe. |
Bruce Hinds |
Jan 4 2015, 12:23 AM
V-8 madness Group: Members Posts: 733 Joined: 27-December 06 From: Port Orchard, WA Member No.: 7,391 Region Association: Pacific Northwest |
I think there is supposed to be a spacer behind the adjustment nut.
JawjaPorsche |
Jan 4 2015, 06:17 AM
Advanced Member Group: Members Posts: 3,463 Joined: 23-July 11 From: Clayton, Georgia Member No.: 13,351 Region Association: South East States |
I think there is supposed to be a spacer behind the adjustment nut. (IMG:style_emoticons/default/agree.gif) See picture below. You are missing the part between 61 and 62. You can use oversized nuts as spacers. Attached thumbnail(s) |
Hank914 |
Jan 4 2015, 08:06 AM
Thank you for the comments. I'll get to the hardware store today.
rhodyguy |
Jan 4 2015, 11:00 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,089 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
you're missing the little clip that retains the cable where it enters the bracket too. double nut the threaded end after you find the correct adjustment.
Lo-Fi Version | Time is now: 5th June 2024 - 12:58 AM |
