Type 4 |
Member ![]() ![]() Group: Members Posts: 412 Joined: 30-September 04 From: Costa Mesa Calif. Member No.: 2,866 ![]() |
Type4parts is your source for Type4 Machine work.
John Edwards our Machinist has over Thirty years of experiance in the world of Automotive machine work. John has been an Engine building Educator. John is the author of Sunnen's Complete Cylinder head and Engine Rebuilding Handbook. This book is used worldwide in learning instituions to train Automotive machinists. There isnt a machine work job that we cant do here at Type 4 parts. NDT Expert Visual Inspections Magnetic Particle Inspection Dye Penetrant Teesting Pressure Testing Vacuum Testing Ultrasonic Thickness Testing Surface Finish Measurement Spring Pressure Testing Precision Measurement to 0.0001 Head Work Twin Plug Conversion Heads opened up for 103-105 Cylinders Precision Mulit-angle Seats Centerless Valve Grinding Oversized Valves Giude and Valve Relocation Resurfacing Porting and Polishing Flow Testing on Superflow Case Work Open up Case for 103-105 Cylinders Alignboring Machine Case for Type 1 Lifters Lifter Boring and Sleeves Deck Truing Lifter Refacing Cylinders Boring for Larger Pistons Sealing area Ridge for High Comprssion Tops Trued Custom Cylinder Sleeving for Reduced bore Crankshaft Bend Measurements Grinding&Polishing Chamfering Oil Grooving Counterweights Keyway Reconstruction Dowel Pin Installations Connecting Rods Resizing Alignment Balancing Pin Bushing Conversions Pin Oilers Weight Reductions Balancing Crankshafts Connecting Rods & Pistons Flywheels Crack Repairs Dropped Seats and Combustion Chamber Repairs Corrosion Damage Cleaning Biomatic Parts Washer Pressure-Pt Sand Blaster Thermal Cleaning System Aqueous Pressure Washer Welding Oxy-Acetylene AC/DC Arc Heliarc (TIG) MIG Simtester Engines Borken in On-The-Stand An Inexpensive Alternative to Dyno Testing Dynometer 1600Hp Computerized Engine Dyno Custom Running Cycles Mill &Lathe Work Genuine Bridgeport Mill and Lathe DRO Equipped Fabrication Intake Manifolds Exhaust Headers R&D Projects If you can dream it up, Type 4 Parts can help bring your projects to completion. |
Lo-Fi Version | Time is now: 11th July 2025 - 05:22 AM |
