shock experts, question on contruction |
mskala |
Feb 15 2005, 11:08 AM
R Group: Members Posts: 1,925 Joined: 2-January 03 From: Massachusetts Member No.: 79 Region Association: None |
Okay, got some older Koni sports that were lying
around (in struts) for who knows how long. In checking them out, I found that there is no oil in either of them. Now it was not difficult to open one, put in oil (hydraulic fluid), and see it damp right again. Question is, are these supposed to be totally sealed? I didn't see anything like that. If you store them upside down will they empty? Anybody got an exploded view of the innards? Thanks, |
ArtechnikA |
Feb 15 2005, 11:44 AM
rich herzog Group: Members Posts: 7,390 Joined: 4-April 03 From: Salted Roads, PA Member No.: 513 Region Association: None |
try here. there's a link to Koni's site in that thread too...
mskala |
Feb 15 2005, 06:19 PM
Thanks, I hadn't seen that area of the site before.
Have to look closely at the diagrams. |
Dave_Darling |
Feb 16 2005, 05:30 PM
Are you talking about there being zero oil inside the shock absorber itself, or none in the strut between the shock and the tube of the strut?
In the latter case, the shocks may be just fine. The oil (or antifreeze in some cases) is there notionally to help heat transfer from the shock to the outside air. Not critical; many people skip this. If you opened up the insert itself (the shock), umm... I don't really know how you'd do that! --DD |
mskala |
Feb 16 2005, 06:29 PM
Sorry it's tough to be clear unless I'm talking in binary 0010100011 (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) I took the shocks out of the struts (boge, it appears), and the rod moves with very low resistance. Unrelated, the giant nut for the strut is super-stuck on the shock, now out of strut. So, bang on the nut a few times around the edges, and nut plus whatchamacallit comes off. There is no seal or o-ring on it, I can take a pic. _No_ oil inside. Since the other one is the same feel and weighs the same, I assume both are empty. That couldn't be leakage. Or strut would be full of oil. (IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif) |
ArtechnikA |
Feb 16 2005, 08:28 PM
okay - so - Boke, not Koni, they were probably black, early ball-joint struts, yes ?
*original* 914.6 struts. these ran with *no* inserts - the outer tube *was* the monotube, and the damper piston and seals ran directly in (smelly) oil in the strut tube. my cars had that too. get some good inserts, add a bit of oil to the tue for heat transfer (unless yours have cracks, which would be where the original oil went...) and you'll be good to go. although if you suspects cracking, a Magnaflux might be in order ... |
r_towle |
Feb 16 2005, 09:05 PM
Custom Member Group: Members Posts: 24,588 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
He bought these...
Attached image(s) |
r_towle |
Feb 16 2005, 09:06 PM
more
Attached image(s) |
r_towle |
Feb 16 2005, 09:07 PM
I dont have a pic of the model numbers, but Mark can provide those...
they are on the side of the shock near the neck. Rich |
Lo-Fi Version | Time is now: 8th June 2024 - 07:55 AM |
