r_towle |
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,591 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States ![]() ![]() |
From what I have learned, little at most....
PDK is a dual clutch transmission that basically shifts ahead of you and is waiting for a click of the paddle to flip from one clutch to the other....the secondary clutch is already engaged and ready to go on any given gear....but its thinking ahead, certainly based on software and accel or decel mode.. So, who else is doing a dual clutch like this? Yes, this is a bit ADD (Scotty) but I am thinking ahead for when a clutch may no longer be a simple part of my daily routine. Does subaru do this, or audi (something I can transplant) or any other car that would not cost me an arm and a leg to transplant? And yes, I may want to flip the tranny, or possibly run it backwards....so mid or rear engine... Rich |
Mike Bellis |
Resident Electrician ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,345 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None ![]() ![]() ![]() |
The Audi DSG has been around for a few years. You can find them in TDI models originally and now in more applications.
r_towle |
thanks,
Looks like 2008 and on are available. I wonder who knows how to flip these around??? |
balljoint |
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,000 Joined: 6-April 04 Member No.: 1,897 Region Association: None ![]() |
We had one in the Golf TDI.
Mike Bellis |
thanks, Looks like 2008 and on are available. I wonder who knows how to flip these around??? Why would you need to flip it around? (IMG:style_emoticons/default/confused24.gif) ![]() You could go with a Mendeola if you want paddle shift. If you want automatic, go with a Boxster triptronic. |
Mike Bellis |
Both the DSG and PDK are massive chunks weighing a few hundred pounds.
http://www.ebay.co.uk/itm/AUDI-A4-A5-A6-20...=item3cf679b776 http://www.ebay.co.uk/itm/PORSCHE-911-997-...=item20d3ca875c |
Andyrew |
Spooling.... Please wait ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,376 Joined: 20-January 03 From: Riverbank, Ca Member No.: 172 Region Association: Northern California ![]() ![]() |
thanks, Looks like 2008 and on are available. I wonder who knows how to flip these around??? Why would you need to flip it around? (IMG:style_emoticons/default/confused24.gif) ![]() You could go with a Mendeola if you want paddle shift. If you want automatic, go with a Boxster triptronic. Mike, thats a R8.... (IMG:style_emoticons/default/smile.gif) |
Mike Bellis |
I know! How awesome would that be in a 914? (IMG:style_emoticons/default/evilgrin.gif) |
914forme |
Times a wastin', get wrenchin'! ![]() ![]() ![]() ![]() Group: Members Posts: 3,896 Joined: 24-July 04 From: Dayton, Ohio Member No.: 2,388 Region Association: None ![]() ![]() |
I ran the VW Tip in a TDI, and it worked well when it work. Huge amounts of power and, I killed it. Went 6 speed then, never looked back.
Issues I had with the Tip, VW programming was not good, Audi sport mode reported to be better. I had paddle shifter setup, and never got the VW to shift in a consistent manner that made the car fun to drive. 6-speed, and a Perqoulin LSD made the car insane to drive. Porsche Tip much better, PDK is even better, but the expense comes with weight. That being said, you can run faster lap times in the rain with a PDK or Tip than us clutch jockeys. I hate flappy paddles, the ill acting Tip was enough for me to get my knee fixed, work through the rehab and suck up the pain, just to drive a car I like. I would install hand controls before, I give up on a clutch. BTW, they make electro servos that can drive the hydraulics to push the clutch in. |
r_towle |
Sorry, thinking about a luxury, cruiser, 356
So rear engine... Subaru powered Automatic is going to be a reality for me at some point....and it takes me forever to get shit done, so I might as well start from the right place. |
Mike Bellis |
Then why not just use the PDK or triptronic out of a 911? Still a 200lb-300lb transmission.
r_towle |
Because I am cheap.
Mike Bellis |
If you want a performance automatic, you can't be cheap. The VW Passat triptronic would be the cheapest way. For about $500 you can find them. You also need the TCM and wire harness. Then you need to figure out machine work to get a starter near the 914 position. You would also need to figure out a way to trick the TCM into working correctly.
The Passat trannies are basically Boxster trannies for a fraction of the price. The best way to do this is to buy a 1997 Boxster and use the engine and tranny. Whoops, water cooled. Early Boxsters with automatics can be had for under $7k |
drive-ability |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,169 Joined: 18-March 05 From: Orange County, California Member No.: 3,782 ![]() |
I am running a G-50 5 speed but really want an auto in my car. I'm trying to sort the car now but will be looking for a suitable auto. I would like to here more about
the options (IMG:style_emoticons/default/sawzall-smiley.gif) (IMG:http://www.914world.com/bbs2/uploads_offsite/i60.photobucket.com-3782-1430205254.1.jpg) |
bandjoey |
bandjoey ![]() ![]() ![]() ![]() Group: Members Posts: 4,929 Joined: 26-September 07 From: Bedford Tx Member No.: 8,156 Region Association: Southwest Region ![]() |
Why dual clutch? Paddle shifters are becoming a standard on FWD sports sedans and some RWD. From Hyundai RWD used on 3.8 and 5.0L motors:
"TRANSMISSIONS The automatic transmissions for both engines have 8-speeds, with an enhanced paddle-shifter design for the SHIFTRONIC® manual-shifting capability. In addition, the 8-speed automatic now precisely rev-matches engine RPM to the exact selected-gear speed, for smooth downshifts into corners and superb dynamic balance. Both engines are mated to standard six-speed manual transmissions that feature new carbon synchronizer rings for smoother shift action and enhanced synchronizer durability. Each transmission has been specifically tuned to match its engine’s unique power and torque curve characteristics. In addition to the steering wheel-mounted paddle shifters, each automatic offers shift capability via the shift lever according to individual driver preference. A clear LCD readout on the instrument panel shows the selected gear at all times for the driver." Looks like paddle shift options are growing yearly. |
r_towle |
Why dual clutch? Paddle shifters are becoming a standard on FWD sports sedans and some RWD. From Hyundai RWD used on 3.8 and 5.0L motors: "TRANSMISSIONS The automatic transmissions for both engines have 8-speeds, with an enhanced paddle-shifter design for the SHIFTRONIC® manual-shifting capability. In addition, the 8-speed automatic now precisely rev-matches engine RPM to the exact selected-gear speed, for smooth downshifts into corners and superb dynamic balance. Both engines are mated to standard six-speed manual transmissions that feature new carbon synchronizer rings for smoother shift action and enhanced synchronizer durability. Each transmission has been specifically tuned to match its engine’s unique power and torque curve characteristics. In addition to the steering wheel-mounted paddle shifters, each automatic offers shift capability via the shift lever according to individual driver preference. A clear LCD readout on the instrument panel shows the selected gear at all times for the driver." Looks like paddle shift options are growing yearly. automatics have torque converters, PDK is a dual clutch system, just a faster setup. |
VaccaRabite |
En Garde! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 13,465 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region ![]() |
Sccob paddle shifters are just CVTs that use the paddles to (sort of)lock the trans in gear. I dont like them. They act better in CVT mode.
Zach |
Chris H. |
Senior Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,032 Joined: 2-January 03 From: Chicago 'burbs Member No.: 73 Region Association: Upper MidWest ![]() ![]() |
Weird. Friend of mine just bought a pretty new GTI and I was about to ask Mike about the feasibility of putting a trans like his 6 speed DSG in a 914...that thing shifts so smoothly and yet instantaneously! It's amazing. I assume the only way to get it to work perfectly would be to swap both the engine/trans with whatever you pull it out of? Audi A4 comes with a 7 speed....
naro914 |
Losing my mind... ![]() ![]() ![]() ![]() Group: Members Posts: 2,476 Joined: 26-May 06 From: Charlotte, NC Member No.: 6,073 Region Association: South East States ![]() |
Because I am cheap. I don't think there will be a cheap way to do this. If we can't figure out a simple/cheap way to mate a manual Boxster trans to an air cooled engine, I can't even imagine how much more complicated this would be. The PDK type trans is fully integrated with the engine management system, which is fully integrated with the engine (obviously). They work as a unit, not individually, so I'm not even sure it would be possible without doing both. Honestly, the cheapest option would be to buy a very cheap Boxster Tiptronic (which can be had for under $10k) and use all of engine/trans/wiring/ECU for it. |
r_towle |
Because I am cheap. I don't think there will be a cheap way to do this. If we can't figure out a simple/cheap way to mate a manual Boxster trans to an air cooled engine, I can't even imagine how much more complicated this would be. The PDK type trans is fully integrated with the engine management system, which is fully integrated with the engine (obviously). They work as a unit, not individually, so I'm not even sure it would be possible without doing both. Honestly, the cheapest option would be to buy a very cheap Boxster Tiptronic (which can be had for under $10k) and use all of engine/trans/wiring/ECU for it. A few things.... I am looking for a rear engine solution, but if a boxster tranny is available for a setup, I will design and figure out what needs to be done to bolt it to our motor. Its a bell housing that needs to be swapped over and a clutch/pressure plate we need to use that works with the motor.... For the PDK, yes, its integrated with the car, but it has its own computer and its reading throttle body, speed, and a few other sensors that could all be setup using a different interface. Again, I am NOT looking for the porsche PDK tranny...I am looking for something cheaper like a subaru/toyota/whatever to be able to create a solution that will actually work.... I know I could buy a PDK and at that point it makes sense to buy a late model 911 and call it a day... That defeats the purpose. Let me see if I can get my hands on a boxster tranny and get that settled because I am tired of waiting for someone to do it for us. (IMG:style_emoticons/default/smile.gif) rich |
Lo-Fi Version | Time is now: 16th June 2024 - 11:35 AM |
