What type of plastic are the headlight motor covers |
Geezer914 |
Jul 7 2015, 03:09 PM
Geezer914 Group: Members Posts: 1,443 Joined: 18-March 09 From: Salem, NJ Member No.: 10,179 Region Association: North East States |
I have a cracked headlight motor cover I want to repair. What type of plastic are they made of so I can get the correct type of cement for a permanent repair? (IMG:style_emoticons/default/confused24.gif) Thanks
JeffBowlsby |
Jul 7 2015, 09:17 PM
914 Wiring Harnesses Group: Members Posts: 8,533 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
I would guess polystyrene, or possibly ABS (Acrylonitrile Butadiene Styrene).
Maybe get an old broken one and experiment on it first. |
PanelBilly |
Jul 7 2015, 09:29 PM
914 Guru Group: Members Posts: 5,817 Joined: 23-July 06 From: Kent, Wa Member No.: 6,488 Region Association: Pacific Northwest |
Figure out who your 3M rep is in your city. They make all kinds of glues and can recommend the best thing for you and tell you where to buy it
Chris914n6 |
Jul 7 2015, 11:43 PM
Jackstands are my life. Group: Members Posts: 3,333 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region |
The hobby store will have glue that works on both styrene and abs, assuming Jeff is right... (IMG:style_emoticons/default/beer.gif)
Most of the injected stuff is abs. |
JeffBowlsby |
Jul 8 2015, 04:20 PM
ABS is the common black plastic plumbing pipe, ABS 'cement' would work well. Its really a solvent not an adhesive.
Model car kits are styrene, so model cement should work. I am sure there are others glues/adhesives/solvents that would work, why I suggested experimenting on a broken one. |
Geezer914 |
Jul 8 2015, 04:34 PM
Thanks for the replies. I used Testors Model cement. It did the trick. (IMG:style_emoticons/default/driving.gif)
JeffBowlsby |
Jul 8 2015, 04:38 PM
Ah...its in the styrene family of plastics then. Good to know.
Chris914n6 |
Jul 8 2015, 11:51 PM
JeffBowlsby |
Jul 9 2015, 08:27 AM
"Styrene and ABS Plastic Solvent Cement"
ABS = "Acrylonitrile butadiene styrene" Further proof that the are styrene. What am I not understanding fro your post? |
Lo-Fi Version | Time is now: 7th June 2024 - 07:36 PM |
