Trying to run previously carb'd 1.8 on FI |
aarch |
Jul 31 2015, 08:28 AM
Newbie Group: Members Posts: 1 Joined: 31-July 15 From: Cape Cod, MA Member No.: 19,013 Region Association: North East States |
I got a free 1.8 engine (EC005197) that had previously been set up with carbs. All I got was the engine, no FI or carbs. I have a '72 1.7 with the original engine and FI. I swapped out the engine and put the entire original 1.7 fuel system (FI, computer, throttle) onto the 1.8. Where the original 1.7 was anemic at best, the 'new' 1.8 was much, much stronger. It pulled far stronger, revved faster, and under any throttle it ran perfectly smooth. I've never dyno'd either, but it felt like ~20hp increase. However, under neutral throttle, at cruising speed the power output would stutter/hesitate. It didn't misfire, sound rough, or cutout; it just wouldn't maintain a steady speed.
At the time I thought it might be a vacuum problem, but I'm wondering if it was a cam issue. Did all that extra power come from a high performance, carb-tuned cam that won't work with the FI? Or is it an incompatibility with the 1.8 engine and the D FI from the 1.7? I ended up putting the original engine back in it. It's a shame to have that beast of a 1.8 just sitting in the basement though. Any thoughts would be much appreciated. Thanks, Andy |
Dave_Darling |
Jul 31 2015, 08:47 AM
Probably cam related. The 1.8 was rather lower compression than the 1.7, and actually made less power. (76 HP DIN vs. 80 HP DIN spec.)
--DD |
Spoke |
Jul 31 2015, 09:04 AM
Jerry Group: Members Posts: 6,989 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
jimkelly |
Aug 2 2015, 09:05 AM
Delaware USA Group: Members Posts: 4,969 Joined: 5-August 04 From: Delaware, USA Member No.: 2,460 Region Association: MidAtlantic Region |
from what I've read here, even if an engine has carbs, there is a low percentage chance that the engine itself has a carb cam in it. I wonder if there is a way to turn the engine with plugs out and watch the rocker action to determine if engine actually has a carb cam in it???
all the best. |
Tbrown4x4 |
Aug 2 2015, 09:20 AM
Senior Member Group: Members Posts: 704 Joined: 13-May 14 From: Port Orchard, WA Member No.: 17,338 Region Association: None |
You need a degree wheel, a dial indicator and the cam specs. Then you basically map the lift and duration and compare it to the cam specs.
I'm not too familiar with VW/Porsche engines, but if you pull the oil pump, is there any ID marks on the end of the cam? |
SirAndy |
Aug 2 2015, 12:11 PM
Resident German Group: Admin Posts: 41,670 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
I'm running DJET from a '71 1.7L on a 1.8L with no problems. Runs like a champ. (IMG:style_emoticons/default/agree.gif) I ran a 1.7L D-Jet on a 1.8L block with no problems. Might be a carbed cam in the 1.8L block ... (IMG:style_emoticons/default/idea.gif) |
rhodyguy |
Aug 2 2015, 12:31 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,085 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
Could even be a 1911. No telling. But if it was rebuilt and "setup" for carbs you might consider a loaner or rental set to see how it works. You're into the engine at the right price. Throw a little money at it. Would a struggling MPS cause the stutter/hesitation?
Lo-Fi Version | Time is now: 3rd June 2024 - 09:22 AM |
