Engine won't start, Real on topic stuff |
TheCabinetmaker |
Mar 3 2005, 08:28 AM
I drive my car everyday Group: Members Posts: 8,301 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
My 75 2L has 115,000 miles, leaks oil from everywhere, has low comp, low oil pressure, and leaks oil from everywhere. I pulled a strong dry 2L from my son in laws (on rails), crashed car ( he went off rails). Yesterday I pulled my engine, swapped the FI stuff over and put his in my car(not bad for 1 days work). Now it won't start. It gets spark, and the injectors are firing. I'mm 99.999% sure everything is hooked up right. CHT reads 2000 ohms. I'm gonna pull the air cleaner from his new car today to verify everything is hooked up correctly.
Any ideas would be greatly appreciated. |
ArtechnikA |
Mar 3 2005, 08:33 AM
rich herzog Group: Members Posts: 7,390 Joined: 4-April 03 From: Salted Roads, PA Member No.: 513 Region Association: None |
fuel pressure? timing?
fuel, compression, and properly timed spark are all you need ... |
JoeSharp |
Mar 3 2005, 08:36 AM
In Irvine, Ca. May 15-18 Group: Members Posts: 3,947 Joined: 9-July 03 From: DeLand, Florida Member No.: 898 Region Association: South East States |
(IMG:http://www.914world.com/bbs2/html/emoticons/agree.gif) Yeah! What he said. (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif)
Back to the basics. Check your grounds. Fuel pressure. Timing. On the last car I did I wound up carbed. (IMG:http://www.914world.com/bbs2/html/emoticons/huh.gif) Something is not hooked up. (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) Joe |
TheCabinetmaker |
Mar 3 2005, 08:40 AM
Fuel pressure is 29/30. Timing is close enough to start. Yesterday was a long day. I'm gonna go look at it today in a different light. I'll double check valves too.
I agree Joe, something is not hooked up right. |
Joseph Mills |
Mar 3 2005, 08:57 AM
on a Sonoma diet now... Group: Members Posts: 1,482 Joined: 29-December 02 From: Oklahoma City, OK Member No.: 39 |
Was that engine ever started backup after he "went off the rails". (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif)
Re-check all the engine wiring connections. Coil? |
TheCabinetmaker |
Mar 3 2005, 09:00 AM
Hi Joseph, the engine was actually still running when he was suspended across the creek. It's been started a few times since then.
Bruce Allert |
Mar 3 2005, 10:48 AM
Hellions asleep Group: Members Posts: 3,289 Joined: 19-March 03 From: Eagle Creek, Orygun Member No.: 441 Region Association: Pacific Northwest |
Hey Curt, mine did that and I foound the 2 wires on the coil were backwards. That's the extent of my knowledge.
good luck (IMG:http://www.914world.com/bbs2/html/emoticons/beer.gif) (Fat Tire) ..........b |
ClayPerrine |
Mar 3 2005, 10:53 AM
Life's been good to me so far..... Group: Admin Posts: 15,503 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
Get out your propane torch. Feed the nozzle down the throttle body, turn it on and see if the car will start. If it does, then its a fuel system problem. If it doesn't start, then it's ignition related.
Remember, to get a car to start, you have to think FAST. F - Fuel.... is it getting fuel? A - Air.... valve adjustments correct? S - Spark...is the ignition working? T - Timing... is everything happening at the correct time? Good luck!!! |
Jeffs9146 |
Mar 3 2005, 10:55 AM
Ski Bum Group: Members Posts: 4,062 Joined: 10-January 03 From: Discovery Bay, Ca Member No.: 128 |
Ground wire (Trany strap)? Points? Oil pressure sender wire hooked to the coil??
throtle body flap stuck closed? Does it smell like gas? OLD GAS?? (IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif) Jeff |
TheCabinetmaker |
Mar 3 2005, 11:29 AM
Got it, and we were all wrong except maybe clay. The engine had a single carb before I switched it. The diz drive was off by one notch. (IMG:http://www.914world.com/bbs2/html/emoticons/smilie_pokal.gif) Timing. timimg, timing.
Rich was right on too. properly timed spark This post has been edited by vsg914: Mar 3 2005, 01:15 PM |
ClayPerrine |
Mar 3 2005, 11:36 AM
Now you have a nice new motor to go play in April....... (IMG:http://www.914world.com/bbs2/html/emoticons/boldblue.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/driving.gif)
TheCabinetmaker |
Mar 3 2005, 12:18 PM
Talimena will be fun. The 2056 I build out of my old motor will be even more fun. (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif)
TheCabinetmaker |
Mar 3 2005, 07:18 PM
Thanks to all. Drove the car to dinner tonight, and besides the exhaust leak, it runs great. Adding the vacuum advance equipped throttle body, really helped with the low end torque (75 FI system). I'm not sure why, but this new engine has the best throttle response of any 4 I've driven.
redshift |
Mar 3 2005, 09:43 PM
Bless the Hell out of you! Group: Members Posts: 10,926 Joined: 29-June 03 Member No.: 869 |
Oh yeah! And that is a good thing! YaY!
M |
Lo-Fi Version | Time is now: 1st June 2024 - 09:35 PM |
