FS: Red 1975 2.0l |
FS: Red 1975 2.0l |
LevisJeanz |
Sep 13 2015, 10:26 PM
Newbie Group: Members Posts: 7 Joined: 3-March 12 From: Seattle, WA Member No.: 14,210 Region Association: Pacific Northwest |
Link to picture album:
(it might ask you to sign up, just close the box) https://www.dropbox.com/sh/nt3toq13f8yg20e/...nzCUd4FW6a?dl=0 Current condition: Running and rebuilt 2.0l engine and a chassis with a few spots with very little surface rust where the original paint on the exterior has been compromised. The car runs, and drives. I have driven it up to freeway speeds. The entire brake hydraulic system has been rebuilt. The Engine: Rebuilt from the ground up. New parts include dual 34ICT carbs, distributor, ignition wires, plugs and various smaller components. Engine Compartment/Battery shelf: The battery shelf area has been completely repaired and painted. The rear trailing arms have also been repaired painted. The battery has been relocated to the center of the rear trunk compartment. Strut braces have been welded in and painted between the rear shock towers. The Transmission, Clutch, and Shifter: The clutch disk and pressure plate are new from Pelican Parts and the flywheel has been machined to the specified tolerances by a trusted shop. The new clutch disk is the 6 spring upgrade from the 911 of that year. It is an improvement over the 4 spring clutch disk that that was originally equipped. The shift lever has been rebuilt with the bushing kit available on pelican. The transmission has all new fluids and shifts into all gears. The Brakes: 4-wheel disc brakes. Rotors are in good condition and the calipers have been rebuilt with a kit available from pelican parts. New braided stainless steel brake lines. The brake master cylinder is a brand new OEM equivalent, not the variant that has been prone to leakage. New performance pads. Suspension: The suspension is in good shape. Wheels/Tires: Installed are 4 brand new Khumo Ecsta 4X performance tires. 205/65R15. The rims are the Riviera style and are painted black. Interior: The interior is black and dash vinyl has a few narrow cracks. Black carpet that has been temporarily glued in place. Although it is easy to pull up if needed. ( I have had to on occasion to troubleshoot various things.) The seats are in good condition. The passenger seat has a small tear in the left bolster that I have covered and looks pretty good. The gas pedal has been replaced with a CNC milled aluminum part that feels much more accurate that stock. I also have matching CNC milled pedals for the clutch and brake that I haven't installed. Installed is the original Blaupunkt tape player that was installed as a dealer option. I still have the factory speakers although they aren't installed because I planned on upgrading. The rear window seal is brand new with OEM equivalent material. Body: The body has a few dents and a the paint job will need polishing and wax to bring some of the shine back. Issues: I am currently working to get the driver side blinker to work without blowing a fuse, wheels need to be balanced. Other notable or new parts: New Hella Headlights performance exhaust new Dual carbs ( replaced a failing FI system that I still have the parts for) Modern Thermostat replacement to control the flaps in the engine tin new seals for the oil cooler New Head Temp Sender New Oil pressure sender (for the dash light) New VDO Head temp gauge ( shows actual number values to help avoid engine damage) Gas tank cleaned and fuel sender rebuilt I have put a little over 3 years of work into this car and would like to see it go to another passionate Porsche owner, hopefully someone with plans of using it for motorsports. . Asking $5000 OBO Thanks for taking the time to read through everything! Please feel free to contact me I am open to offers and will do my best to answer any questions that you may have. Pictures: https://www.dropbox.com/sh/nt3toq13f8yg20e/...nzCUd4FW6a?dl=0 |
914z |
Oct 8 2015, 06:58 AM
Newbie Group: Members Posts: 35 Joined: 11-September 04 From: Los Angeles, CA Member No.: 2,737 |
PRICE?
iwanta914-6 |
Oct 8 2015, 07:39 AM
Senior Member Group: Members Posts: 718 Joined: 26-June 09 From: Minnesota Member No.: 10,510 Region Association: None |
dinnyin |
Oct 18 2015, 03:51 PM
I'm new here ... Group: Members Posts: 0 Joined: 9-August 15 From: SoCal Member No.: 19,042 Region Association: Southern California |
Have some more pics (esp. of the common problem areas)?
Is there a known-to-914World shop in the area for a PPI? thanks |
Confused |
Oct 29 2015, 07:36 PM
Newbie Group: Members Posts: 4 Joined: 14-May 13 From: Villa Hills, KY Member No.: 15,871 Region Association: None |
Lo-Fi Version | Time is now: 10th June 2024 - 04:13 AM |
