> Radiator Suggestions for Blue Porscheru, Will the Scirocco radiator really work?
R_u_dd
post Sep 27 2015, 01:41 PM
I ordered a Scirocco style radiator for my Subaru 2.5 NA conversion. It measures approximately 20" X 11" X 1.5" and is a double pass. The stock radiator measures 13.38 X 27 X 5/8". The scirocco radiator has more surface area if I consider that it is a double pass and twice as thick ie 440 square inches versus 361 square inches. Am I safe to assume that the scirocco (though smaller and thicker) will have the same or better cooling power as stock?
(IMG:http://www.914world.com/bbs2/uploads_offsite/i1301.photobucket.com-17072-1443382875.1.jpg)
Details here: Radiator portion of thread.
Mike Bellis
post Sep 27 2015, 03:49 PM
Resident Electrician
I think It will work fine as long as it is properly ducted and sealed.
I'm running a Celica GTS rad on my conversion. It fits the trunk space better and is about the same height. Check out the last few pages of my build thread for pics.
R_u_dd
post Sep 27 2015, 04:45 PM
QUOTE(Mike Bellis @ Sep 27 2015, 02:49 PM) *
Is your Celica radiator a single pass radiator? I am hoping the thickness of this radiator makes up for the surface area and that the effective cooling area is actually greater.
R_u_dd
post Sep 27 2015, 05:15 PM
Good design Konzept, or does your license plate mean Kids inept?? Just a joke no offense.
Is that the 916 bumper in fiberglass?
Also, where did you come up with those headlights. I think I saw somewhere in another thread that they are cut from another car. Was that also the Celica? I suppose that I could find that in your thread as well. Do you know what page that would be on?
914forme
post Sep 27 2015, 06:40 PM
I'll add what I put in your build post.
Your rad is good for 400HP with a kludged fan, and 600 if you use their fan. I believe the difference is that they don't want the liability for a bad design.
Mike Bellis
post Sep 27 2015, 07:29 PM
QUOTE(R_u_dd @ Sep 27 2015, 04:15 PM) *
Its a modified GT bumper from QRS. I raised the cut out 2" to better fit my oil cooler.
Headlights are modified 240sx units. Cut down on all 4 sides and fiberglassed underneath, brackets mount to stock holes. Not one angle matched the 914 so I made a template and cut them down to size/shape. The lights are not in my build thread. I think there is another thread about headlights that has info. But it was a couple years ago.
Celica rad is single pass but works really well. Yours should work well with the Subie engine as well. I used mine as it was less work and a cleaner install on the shroud.
Andyrew
post Sep 27 2015, 10:10 PM
Spooling.... Please wait
I've got the same radiator as Mike mounted a bit further to the front if your looking for another install. (signature)
I think your radiator would be just fine, I initially thought it was to small then I saw it was double pass and fairly thick. Put a high dollar fan on it and shroud it really well and I doubt you will see any issues.
- Lo-Fi Version Time is now: 28th October 2026 - 06:04 PM
