Mueller |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 17,155 Joined: 4-January 03 From: Antioch, CA Member No.: 87 Region Association: None ![]() ![]() |
'73 with rebuilt 1.7 that is assumed to be more or less stock, even if it is warmed over a tad bit it is still not a powerhouse of a power plant (IMG:style_emoticons/default/smile.gif)
I have a choice of rims for final build.... 16x7 using one inch spacers (that more or less makes the wheel combo set heavier) (currently has 205's) or 15x5.5, no spacer. (currently has 195's) Both sets need brand new tires and since not a race car and it might see one auto-x a year no need for super sticky tires. So lets say both would get same brand middle of the road tire. I'm thinking the smaller setup would be better right off the bat due to be a lighter combo however would the lateral grip be better with the wider setup? Being a street car and being the responsible person I am, I'd venture to say that I wouldn't ever reach the point of needing the extra lateral grip if that is a something that the one combo would excel at. (IMG:style_emoticons/default/smile.gif) |
jmitro |
Senior Member ![]() ![]() ![]() Group: Members Posts: 713 Joined: 23-July 15 From: Oklahoma Member No.: 18,986 Region Association: None ![]() ![]() |
all things being equal, yes the wider rim would give you better grip, even with same size tire since less sidewall roll.
but there are many variables that go into your choice of narrow vs wide, and I'd say that tire grip is probably one of the least for a street car that never sees the limits of grip |
siverson |
Advanced Member ![]() ![]() ![]() ![]() Group: Benefactors Posts: 2,458 Joined: 5-May 03 From: San Diego, CA Member No.: 654 Region Association: Southern California ![]() ![]() ![]() |
it probably actually makes a difference after youve spent about 100 hours at drivers schools. (IMG:style_emoticons/default/smile.gif)
stevegm |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,111 Joined: 14-July 14 From: North Carolina Member No.: 17,633 Region Association: South East States ![]() ![]() |
What engine? John Forbes frequently mentions "over-tiring" these cars, if there isn't enough engine to make up for it.
anderssj |
Dog is my copilot... ![]() ![]() ![]() Group: Members Posts: 1,750 Joined: 28-January 03 From: VA Member No.: 207 Region Association: MidAtlantic Region ![]() ![]() |
I think the overall footprint would be almost the same area (sq inches--the 195's footprint would be a tad longer, 205s a tad wider) so probably not much difference if they are the same tread, compound, etc. Biggest difference is that the 205s on a 16x7 wheel would have a shorter--and straighter--sidewall, so probably a sharper turn-in when compared to 195 on a 15x5.5. Ride quality on the 205s would likely also be a little stiffer than with the 195s . . . .
A short discussion of the subject at Tire Rack's site: http://www.tirerack.com/tires/tiretech/tec...e.jsp?techid=10 And here's a more in-depth discussion if/when you have the time: http://www.performancesimulations.com/wp/f...-tire-pressure/ FWIW, I'm kind of facing the same question--I have all the stuff to do a 5-lug conversion, as well as a set of 5 OEM Pedrinis. FWIW, I'm leaning towards refinishing the Pedrinis with 196/65HR15 tires just to keep more of a stock look (at least for today). As near as I can tell, for a DD car biggest down-side to the 15x5.5 wheels would be the lack of selection when it comes to tires. Hope this helps! |
Andyrew |
Spooling.... Please wait ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,380 Joined: 20-January 03 From: Riverbank, Ca Member No.: 172 Region Association: Northern California ![]() ![]() |
Grab some sticky tires and I think itll still handle better than 90% of the cars on the road... direction changes should be better with narrow tires
cwpeden |
Great White North, huh? ![]() ![]() ![]() Group: Members Posts: 916 Joined: 20-August 06 From: Victoria BC Member No.: 6,693 Region Association: Canada ![]() |
Another factor is un-sprung weight.
GeorgeRud |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,725 Joined: 27-July 05 From: Chicagoland Member No.: 4,482 Region Association: Upper MidWest ![]() |
Unless your car is flared and has a significant power increase, I'd stick with the smaller rims and tires. You won't notice any real difference on the street and the car will be lighter and easier to steer with the original size.
My conversion car with 7" and 8" rims steers much heavier than my stock -6, and can be quite a handful at low speeds while parking. |
mepstein |
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 19,970 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region ![]() ![]() |
Is wider better. Sometimes it can be fun to get a little loose.
Johny Blackstain |
Walnut Elite Stratocaster player ![]() ![]() ![]() ![]() Group: Members Posts: 3,434 Joined: 5-December 06 From: The Shenandoah River Member No.: 7,318 Region Association: MidAtlantic Region ![]() ![]() |
Attached image(s) ![]() |
Mike Bellis |
Resident Electrician ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,347 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None ![]() ![]() ![]() |
Just before you loose the coefficient of traction...
0396 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,046 Joined: 13-October 03 From: L.A. Calif Member No.: 1,245 Region Association: Southern California ![]() |
Couldn't have said it better. But then, that's where the real driving comes in. Narrow or wide, its all a personal preferences.
jimkelly |
Delaware USA ![]() ![]() ![]() ![]() Group: Members Posts: 4,969 Joined: 5-August 04 From: Delaware, USA Member No.: 2,460 Region Association: MidAtlantic Region ![]() |
I think I am seeing the downside of a tall sidewall right now with 195x65x15 but maybe my rear sway bar is playing a big role. may disconnect it to see if there is any improvement. still need to get an alignment too.
that said, i'd say some lower profile tires is important, thus a taller wheel 16" or 17" may be the solution for me. |
Chris914n6 |
Jackstands are my life. ![]() ![]() ![]() ![]() Group: Members Posts: 3,493 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region ![]() |
I couldn't find sticky tires in stock diameter 15". Just the econobox stuff. So the 16s might be worth it just to get some decent sports car tires.
7s are a tight fit in back, spacers would be pretty thin, depending on camber. My camber is near 0 to get the 225/50-16 7" boxsters 5/16" spacers to not rub the inside. And 215/60-15 on 15x7 944 cookies rub the rolled fender. You might need to mount a used (cheap) tire and trial fit it. |
Elliot Cannon |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Retired Members Posts: 8,487 Joined: 29-December 06 From: Paso Robles Ca. (Central coast) Member No.: 7,407 Region Association: None ![]() ![]() ![]() |
Wider low profile tires look cooler. (IMG:style_emoticons/default/biggrin.gif)
r_towle |
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,705 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States ![]() ![]() |
Narrow tires, less footprint, will give you more of a chance to tune that 1.7 to attain 40 mpg.....or really damn close to it, with tall tires.
But, for me, I would go with the 7 inch 16s Look at Ricks car, he has those wheels, just a nice look. |
r_towle |
Also, tire cost and spacer cost should help with the decision.
Mueller |
Also, tire cost and spacer cost should help with the decision. Sad to admit that I have both setups already... 16x7 Phonedials with spacers on car and 15x5.5 rims with 195/60's sitting under my workbench (IMG:style_emoticons/default/sad.gif) |
r_towle |
16,s
Larmo63 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,267 Joined: 3-March 14 From: San Clemente, Ca Member No.: 17,068 Region Association: Southern California ![]() |
I went with 205/65 x 15s and I should have just gone with 195/65. The tires are just a tad TOO big.
I did notice that right after the full 911 front end surgery, with all new ball joints, turbo tie rods, etc., the steering was noticeably heavier. I don't notice it now though, the car handles like a dream. |
Lo-Fi Version | Time is now: 16th July 2025 - 04:41 PM |
