Carb cc size for 1.7 and 2.0 |
72black914 |
Oct 9 2015, 05:58 PM
Newbie Group: Members Posts: 11 Joined: 27-June 15 From: Ohio Member No.: 18,894 Region Association: Middle East |
I have a 1.7 with empi carbs. I think they're 34cc. I have an opportunity to buy a 2.0 from a VW bus. Will my carbs bolt on the 2.0? Are the 34cc too small and not deliver enough fuel for the 2.0?
I'm a newbie so not up to speed with all abbreviations and slang Thanks He also wants $500 for the 2.0 so is that reasonable? It spins freely but it is a long block only |
G e o r g e |
Oct 9 2015, 06:51 PM
Dr Group: Members Posts: 1,905 Joined: 20-September 05 From: Southern Cal Member No.: 4,832 Region Association: None |
I have a 1.7 with empi carbs. I think they're 34cc. I have an opportunity to buy a 2.0 from a VW bus. Will my carbs bolt on the 2.0? Are the 34cc too small and not deliver enough fuel for the 2.0? I'm a newbie so not up to speed with all abbreviations and slang Thanks He also wants $500 for the 2.0 so is that reasonable? It spins freely but it is a long block only cant answer the carb question, but what engine code is the 2 ltr block, you may find the 1.7 gives you more power. |
Mark Henry |
Oct 10 2015, 10:29 AM
It's mm, not cc.
Real old webers came in 36mm size, but they are likely 40mm. VW bus 2.0 and 1.7 914 are both ballpark 80hp, I don't know the exact numbers offhand. A bus engine will work, but it's lower compression and considered a downgrade for a 914. |
Mueller |
Oct 10 2015, 10:39 AM
It's mm, not cc. Real old webers came in 36mm size, but they are likely 40mm. VW bus 2.0 and 1.7 914 are both ballpark 80hp, I don't know the exact numbers offhand. A bus engine will work, but it's lower compression and considered a downgrade for a 914. Yep, the PO of my car went this route and I am taking it out to put a correct 1.7 back into it. |
72black914 |
Oct 14 2015, 04:00 AM
Thank you, I appreciate the replies. Sorry for the cc vs mm
Lo-Fi Version | Time is now: 6th June 2024 - 05:18 AM |
