Aaron Cox |
Professional Lawn Dart ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 24,542 Joined: 1-February 03 From: Corona, CA Member No.: 219 Region Association: Southern California ![]() |
dizzy says it needs a 3ohm resistance coil......
aircooled.net says that the bosch blue coil isnt adequate for anything above 3k...... so...watcha runnin? after i put the unilite in..... gonna wire up the hyfire box....... (IMG:http://www.914world.com/bbs2/html/emoticons/smilie_pokal.gif) |
machina |
Advanced Member ![]() ![]() ![]() ![]() Group: Benefactors Posts: 2,030 Joined: 21-June 03 From: Miami Beach, FL Member No.: 848 ![]() ![]() |
Jake says Blue and I didn't argue.
Makes big power with it too past 7000 rpm. (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) Attached thumbnail(s) ![]() |
Aaron Cox |
you must have some long wires to run from the cab to the rear trunk....
speaking of.... how long is your coil wire(s) you have one of those cool thru the sheetmetal things |
machina |
The coil wire really isn't that long. Its the standard length that came with my wire kit from Aircooled.net. The leads from the HyFire to the coil are kinda long but it sure doesn't seem to matter. Attached image(s) ![]() |
Aaron Cox |
thanks david....
what is anyone else running? |
Trekkor |
I do things... ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,809 Joined: 2-December 03 From: Napa, Ca Member No.: 1,413 Region Association: Northern California ![]() |
Point of reference: MSD approves of Bosch Blue coil as acceptable, too.
I'm running it. (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) KT Attached image(s) ![]() |
Aaron Cox |
i guess ill give it a try......seems like its the weak link in the super ignition world..... whats the voltage out of a blue coil? |
Trekkor |
Exactly 1.21 Gigawatts (IMG:http://www.914world.com/bbs2/html/emoticons/lol2.gif)
Lo-Fi Version | Time is now: 1st July 2025 - 04:31 AM |
