high idle, when I start the car, idle goes to 4,000! |
914 RZ-1 |
Oct 19 2015, 10:34 AM
Porsche Padawan Group: Members Posts: 683 Joined: 17-December 14 From: Santa Clarita, CA Member No.: 18,230 Region Association: Southern California |
When I start my 1972 1.7L, the idle immediately goes to 4,000 rpm. The only thing I've done recently is replace all the fuel lines down under where the fuel pump is.
All vacuum hoses appear to be connected. I did not remove the air cleaner to check anything under there, but I did tug on them and nothing came loose. It happened like this: stopped the car to open the garage. As soon as I restarted it, it went to 4,000 rpm. I thought I heard a noise in the car (like something came loose or broke or something, but I'm not sure). A friend of mine told me it might be something down around the clutch and gas pedal assembly. I could not find any crossed wires or anything. I do not have a pedal board, by the way. Not sure if that matters, but I mention it in case it does. Any ideas what could be causing this? |
SirAndy |
Oct 19 2015, 11:30 AM
Resident German Group: Admin Posts: 41,676 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
I do not have a pedal board, by the way. Not sure if that matters, but I mention it in case it does. Any ideas what could be causing this? That can cause all sorts of problems since you don't have any pedal stops without the board. You could have snapped off the pelvis that for one of the cables, overextended a cable, broke the clutch tube and a few more possibilities. My guess would be something broke around the pedal cluster and got your accelerator cable stuck. (IMG:style_emoticons/default/idea.gif) |
r_towle |
Oct 19 2015, 07:31 PM
Custom Member Group: Members Posts: 24,588 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
You may have twisted the accelerator cable around the clutch cable.
Check your engine bay, make sure the throttle body is closed. Start the car in neutral without depressing the clutch. If it does not idle super high, gently press the clutch pedal and see if it acts like the gas pedal....making the engine go faster. More than a few of us have done this. Rich |
era vulgaris |
Oct 19 2015, 07:33 PM
J is for Genius Group: Members Posts: 982 Joined: 10-November 13 From: Raleigh, NC Member No.: 16,629 Region Association: South East States |
All vacuum hoses appear to be connected. Appearances can be deceiving. Vacuum leaks can come from the most inconspicuous places, and cause a high idle like you're experiencing. Go through every vacuum hose connection and make sure they're all tight. It would take a significant vacuum leak to get your idle that high. My old '72 car didn't have a pedal board either. As long as you don't lead-foot the pedals like an elephant you should be ok. But maybe remove the air filter and the intake air elbow and see if you can see if the butterfly valve is stuck open. |
74914LE |
Oct 19 2015, 09:12 PM
Member Group: Members Posts: 136 Joined: 6-April 04 From: Fort Worth, TX Member No.: 1,895 |
If it turns out to not be the cable issue as mentioned, you might want to double check your timing. I have had similar issues when the timing was not set properly. The distributor advance could be sticking as well. All kinds of spots for issues to present themselves with D-Jet. Fortunately, with enough time and determination, you can figure it out. Good luck.
Larmo63 |
Oct 19 2015, 09:13 PM
Advanced Member Group: Members Posts: 4,264 Joined: 3-March 14 From: San Clemente, Ca Member No.: 17,068 Region Association: Southern California |
Vacuum hose on the oil breather.
Dave_Darling |
Oct 19 2015, 10:09 PM
4,000 RPM is one heck of a vacuum leak. Probably one of the larger (~13mm) hoses has been knocked off of the manifold. Either that, or the throttle is stuck open a fair bit.
--DD |
914 RZ-1 |
Oct 20 2015, 03:31 PM
I found it! It was the vacuum hose going from the oil breather to the plenum. Not sure how it got knocked off, but it's just a press fit and seems a bit loose. Maybe I should put a fuel hose clamp on it?
The sound I heard must have been the hose popping off the connection. Thanks to all for your advice. Here's an image: The air cleaner has been removed for your viewing pleasure. The hose goes from the "L" connector to the oil breather. |
914_teener |
Oct 20 2015, 07:12 PM
914 Guru Group: Members Posts: 5,205 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
A 1.7 has a vacum hose from the breather tower to the plenum¿
914 RZ-1 |
Oct 25 2015, 08:18 PM
era vulgaris |
Oct 26 2015, 11:33 AM
Oil breather to plenum would be correct
Attached thumbnail(s) |
Lo-Fi Version | Time is now: 7th June 2024 - 07:35 PM |
