stevegm |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,111 Joined: 14-July 14 From: North Carolina Member No.: 17,633 Region Association: South East States ![]() ![]() |
I am embarrassed to admit that during the months I was prepping my car for paint, apparently a light mist of overspray made it onto the dash. Although it isn't a perfect dash, I really don't feel like changing it out.
When I clean it with leather cleaner it comes out looking pretty nice. But, then when it dries, the white comes back. Suggestions as to how I can clean it? Attached thumbnail(s) ![]() |
r_towle |
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,705 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States ![]() ![]() |
Lacquer thinner first.
Acetone if required, but clean that off quickly with windex. |
stevegm |
r_towle |
Test I. A corner, but it should be fine.
Acetone is a lot more harsh.... Both should be cleaned right off with something else, windex or something to cut the oil based product, then soap. |
SirAndy |
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 42,257 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California ![]() |
So, lacquer thinner should be ok? Try on a small piece first, maybe somewhere that isn't readily visible. (IMG:style_emoticons/default/shades.gif) |
r_towle |
Actually goof off works great.
It's soap mixed with lacquer thinner. I have all of it here already, so I keep taking it up a notch until it works.. Acetone is one end of the scale, a wet rag is the other. You may need to use a tooth brush to get into the texture, sad to say. |
sb914 |
Surf Guru ![]() ![]() ![]() ![]() Group: Members Posts: 4,521 Joined: 25-November 12 From: Brookings,Oregon Member No.: 15,191 Region Association: Southern California ![]() ![]() |
What about simple green ,way less toxic
bandjoey |
bandjoey ![]() ![]() ![]() ![]() Group: Members Posts: 4,934 Joined: 26-September 07 From: Bedford Tx Member No.: 8,156 Region Association: Southwest Region ![]() |
And orange hand cleaner and stiff brush. It'll take paint off if it's fairly fresh.
Throw everything mentioned here in a bucket. It's bound to work (IMG:style_emoticons/default/happy11.gif) |
Chris914n6 |
Jackstands are my life. ![]() ![]() ![]() ![]() Group: Members Posts: 3,490 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region ![]() |
Any of the mentioned paint removers are going to dry out the vinyl. Go with a vinyl cleaner and a tooth brush. It all won't come off the first time, let it set. Try again in a week, and another week. The paint will lose it's bond.
914forme |
Times a wastin', get wrenchin'! ![]() ![]() ![]() ![]() Group: Members Posts: 3,896 Joined: 24-July 04 From: Dayton, Ohio Member No.: 2,388 Region Association: None ![]() ![]() |
clay bar?, it was originally designed to remove overspray.
injunmort |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,024 Joined: 12-April 10 From: sugarloaf ny Member No.: 11,604 Region Association: North East States ![]() |
acetone or laquer thinner
bfrymire |
Salsaholic ![]() ![]() ![]() Group: Members Posts: 590 Joined: 1-August 04 From: Sunnyvale, CA Member No.: 2,431 Region Association: Northern California ![]() |
How about just re-dying the dash? Remove as much as possible, and clean before dying.
Just a thought. -- brett |
porschetub |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,879 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None ![]() |
How about just re-dying the dash? Remove as much as possible, and clean before dying. Just a thought. -- brett Most likely the best solution if you use acetone to clean it (IMG:style_emoticons/default/lol-2.gif) ,seriously don't put the stuff near it,it dulls the surface and stays like that,I have used universal thinners which is for laquer and enamel paints and it is weaker. Use small amounts on a white cloth then you can see if the colour is coming off ,do small area's at a time. |
rhodyguy |
Chimp Sanctuary NW. Check it out. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 22,249 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch ![]() |
Try some white vinegar mixed with HOT water in a test spot.
JamesM |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,100 Joined: 6-April 06 From: Kearns, UT Member No.: 5,834 Region Association: Intermountain Region ![]() |
Before messing around with chemicals or anything else, I would try a magic eraser.
http://www.mrclean.com/en-us/shop-products...eraser-original These things are literally about as close as you can get to magic. I have used them to to remove graffiti from all sorts of different surfaces with minimal effort and no impact to the underlying surface. Haven't personally tried them with paint on a dash but i have used them to remove heavy grease staining from white door panels, sharpie writing off plastic, and many other surfaces, paint off of glass and metal. I am always finding new uses for these $2 gems. |
Mr Pharmacist |
Member ![]() ![]() Group: Members Posts: 69 Joined: 15-September 09 From: United Kingdom Member No.: 10,807 Region Association: England ![]() |
I used fine wire wool and water to remove the overspray on my dash. Came up a treat
MJHanna |
Does this 911 make my butt look big? ![]() ![]() ![]() Group: Members Posts: 806 Joined: 23-January 03 From: Lowry Crossing, Texas Member No.: 185 ![]() |
Try rubbing alcohol first before the paint thinner. It's not as harsh.
scotty b |
rust free you say ? ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 16,375 Joined: 7-January 05 From: richmond, Va. Member No.: 3,419 Region Association: None ![]() |
Lacquer thinner will be the best, but as others said try a small spot first. I think the problem you're going to have is the chemicals are going to destroy the outer coating the vinyl has that makes the sheen, and acts as the UV protectant.
Many years ago, I cleaned a set of FILTHY tan seats ( 914 ) with Purple Stuff and a soft plastic bristle brush and ended up removing that coating. The seats ended up very dull, and over a couple years time started to crack apart (IMG:style_emoticons/default/sad.gif) |
stevegm |
Thanks everyone for their suggestions. I am trying Simple Green first. It seems to be working well so far. I will let you know how it goes.
CooltimesJr |
Newbie ![]() Group: Members Posts: 31 Joined: 29-October 15 From: Arlington, Tn Member No.: 19,314 Region Association: None ![]() |
try the Magic Eraser or a generic brand first, we use these all over the house to clean up after the youngin's (pencils, pens, markers, crayons and whatever else twin 4 year olds think will liven up a wall). If that doesn't work, maybe a little simple green or blue liquid dawn in some water. I wouldn't use anything else harsh that would damage the vinyl or cause the paint to thin, smear and then dry again.
Lo-Fi Version | Time is now: 9th July 2025 - 01:36 PM |
