Project Car 914, Pinewood Derby That is.......... |
Garland |
Mar 12 2005, 04:09 PM
Restoration Fanatic Group: Members Posts: 1,329 Joined: 8-January 04 From: ......Michigan...... Member No.: 1,535 Region Association: Upper MidWest |
My son wnated to do a 914 this year. (IMG:http://www.914world.com/bbs2/html/emoticons/smilie_pokal.gif)
Taking shape: Added the finished car to this post below. See the build. Attached image(s) |
Garland |
Mar 12 2005, 04:10 PM
#2
Attached image(s) |
Garland |
Mar 12 2005, 04:12 PM
#3
Attached image(s) |
Garland |
Mar 12 2005, 04:13 PM
Primer
Attached image(s) |
Garland |
Primer#2
Attached image(s) |
Garland |
Mar 12 2005, 04:15 PM
Adding 1st color
Attached image(s) |
Garland |
Mar 12 2005, 04:16 PM
Color # 2
Attached image(s) |
Qarl |
Mar 12 2005, 04:21 PM
Shriveled member Group: Benefactors Posts: 5,233 Joined: 8-February 03 From: Florida Member No.: 271 Region Association: None |
Schweet!
(IMG:http://www.914world.com/bbs2/html/emoticons/clap.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/clap.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/clap.gif) Polish the axles and lube with graphite |
Garland |
Mar 12 2005, 04:52 PM
Adding the body color
Attached image(s) |
Garland |
Mar 12 2005, 04:53 PM
#2
Attached image(s) |
Garland |
Mar 12 2005, 04:54 PM
#3
Attached image(s) |
jd74914 |
Mar 12 2005, 04:55 PM
Its alive Group: Members Posts: 4,780 Joined: 16-February 04 From: CT Member No.: 1,659 Region Association: North East States |
(IMG:http://www.914world.com/bbs2/html/emoticons/agree.gif) It looks great (IMG:http://www.914world.com/bbs2/html/emoticons/smilie_pokal.gif) |
teenrookie |
Mar 12 2005, 06:41 PM
Member Group: Members Posts: 114 Joined: 6-December 04 From: Yorba Linda, CA. Member No.: 3,229 Region Association: None |
Chuck up the axles on your drill press and wet sand to 8000 grit, its like velvet. Watch for the castings near the head.
Next take the wheels and put them in a vice on your drill press. Find a wood dowel that barely fits in the hub of the wheel. Soak one end of the dowel in water, dip it in graphite and chuck it up and polish the inside of the hub, you will leave graphite in the plastic. Chuck up the wheels next andever so slightly shape them so only the middle touches, I hink 600 wet sandtakes it back to original shape. Be careful not make them too convex. People catch that one. Balance the car so it only rides on 3 wheels. Use a dowell to balance it forward, back and left to right. Sink yor big weights deep inside the back of the car, about 35% back. Fishing weights work great when balancing the car after that, you can drill them out to get to exactly the right weight and they are easy to place in the car. My son and I had a ton of fun with soapbox. Have fun and good luck (IMG:http://www.914world.com/bbs2/html/emoticons/smilie_pokal.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/smilie_pokal.gif) |
Garland |
Mar 12 2005, 06:42 PM
Made the Glass
Attached image(s) |
Garland |
Mar 12 2005, 06:43 PM
Sprayed the clear.
Attached image(s) |
Garland |
Mar 12 2005, 06:47 PM
#2
Attached image(s) |
Garland |
Mar 12 2005, 06:48 PM
Hmmmm...
Attached image(s) |
Garland |
Mar 12 2005, 08:04 PM
Trim on
Attached image(s) |
Garland |
Mar 12 2005, 08:05 PM
#2
Attached image(s) |
Garland |
Mar 12 2005, 08:07 PM
#3
Attached image(s) |
Lo-Fi Version | Time is now: 3rd June 2024 - 06:52 AM |
