> AA Steel Flares and 17x9's in Rear, Do they fit?
jmill
post Dec 22 2015, 02:23 PM
Green Hornet
Looking to buy some Euromeisters and all I see is 7's and 9's in 17" rims. Do the 17x9's fit in the rear with AA steel flares? If not, do they need major work (grafting in metal) or just some tugging.
post Dec 22 2015, 02:32 PM
914-6 GT in waiting
Are you sure you want big heavy wheels that don't look right on a 914?
bfrymire
post Dec 22 2015, 02:37 PM
Salsaholic
I have the same rims, except they are 16x9. And they do not fit, as I have 275 Hoosier's on them. Well, they fit but 2mm clearance is not enough for me.
If you use smaller tires they might fit.
Steve
post Dec 22 2015, 02:39 PM
I'm running Fixse 17x9. I have no problems fitting 245x40x17 street tires on the rear
255 will also fit if they don't have the curb rash rib on them.
post Dec 22 2015, 03:06 PM
Resident German
QUOTE(jmill @ Dec 22 2015, 12:23 PM) *
Depends on the offset of the wheels. There is enough space under the flares for a 9" wheel/tire but the offset has to be just right.
The AA flares come with a rather large inner fender lip which can be rolled for a bit more clearance. You can also use spacers and longer studs the move the wheel around a bit.
But, as stated above, the actual offset of the wheel is the most important factor for this.
snakemain
post Dec 22 2015, 03:29 PM
Ronin Member
17x9s Rota Fox Fuchs reps with 245/40 in the rear on mine.
Series9
post Dec 22 2015, 03:34 PM
Lesbians taste like chicken.
The RS has 17x9 Cup IIs with 255 rubber.
We rolled the lips, but they would have fit without doing so.
rick 918-S
post Dec 22 2015, 03:49 PM
Hey nice rack! -Celette
John, I have a 10mm spacer on the rear to clear the inside and a 1/4" round stock rod bonded to the inside of my glas flares as a stiffener. I believe the 16 x 9 and the 17 x 9 euro have the same off set
Elliot Cannon
post Dec 22 2015, 04:05 PM
Group: Retired Members
Spacered to fit. QRS fiberglass fenders. 17X9.
jmill
post Dec 22 2015, 04:32 PM
Green Hornet
QUOTE(mepstein @ Dec 22 2015, 02:32 PM) *
(IMG:style_emoticons/default/unsure.gif) Um, yeah.
Different strokes for different folks, I guess. (IMG:style_emoticons/default/confused24.gif)
jmill
post Dec 22 2015, 04:47 PM
Green Hornet
QUOTE(snakemain @ Dec 22 2015, 03:29 PM) *
I love the look of the RSR Rota Fox. I heard that they had QC issues. Did you have any balance or vibration problems?
jmill
post Dec 22 2015, 04:54 PM
Green Hornet
Rear offset is 16mm. I believe that is stock 911 rear offset.
Cracker
post Dec 22 2015, 05:18 PM
John - I'd take the subjective opinion that 17's "don't look right" with a grain of salt. To some this may be the case; to others maybe not. Nobody mentioned how the wheels "didn't look right" at the track recently and certainly didn't stop them from taking pictures of the car ALL weekend long. Performance wise, the 17"s are better choice for several reasons - no need to beat that to death. Regarding the fitment, I have AA steel flares and run the 7/9 combo. I have plenty of room but also have the flared rears. I run 245 Front & 275 Rear - no issue. Tons of room up front and I run a .5" rear spacer. All the best!
PS: The weight difference is negligible - I went fairly quick.
Tony
jmill
post Dec 22 2015, 05:44 PM
Green Hornet
Tony, are those the RSR finish Rota Foxes? If so did you have any balance or vibration problems? If not I think I'm sold on them. They look awesome.
pete000
post Dec 22 2015, 05:53 PM
I agree the 17's are just too big for the 914. I don't like the 17's on early 911's either. Guess I am getting too old and set in my ways !
I know they are probably superior in performance and tire section has to be good.
I have 16 X 7 and 16 X 8 RSR finish Fuchs on my Six.
I also have a set of 15 x 7 and 15 X 8 RSR finish Fuchs, but tires are getting scarce.
I love the look of both the 15's and 16's on the 914 with M471 fenders.
Cracker
They may be the same but mine are called Linea Corse. However, I can "only" tell you they are rock solid up to 158 mph. LOL!
The look obviously has a more modern flare to it but I'm always into performance before aesthetics. I try to blend the two when I can...
T
bfrymire
post Dec 22 2015, 06:24 PM
Salsaholic
Cracker,
Your flares look different than mine, looks like the lip has been pushed out. I have stock (un-modified) GT flares and the 275 just will not fit. I would be interested in hearing what is different about yours. I need to get the tires to fit. (IMG:style_emoticons/default/smile.gif)
andys
post Dec 22 2015, 06:52 PM
QUOTE(Series9 @ Dec 22 2015, 01:34 PM) *
I have the same wheels with 255-40's and didn't go steel flares because they didn't fit; or at least I thought so until I read your post. I went with Mitcom flares simply because they offer more room.
Andys
snakemain
post Dec 22 2015, 06:54 PM
Ronin Member
QUOTE(jmill @ Dec 22 2015, 04:47 PM) *
No problems at all. Got a couple thousand miles on them during a couple long trips and they ride smooth as glass.
sixnotfour
post Dec 22 2015, 07:23 PM
ya 17's suck, bahahaha!!
last pic 15vs17
- Lo-Fi Version Time is now: 18th March 2026 - 05:51 AM
