Rear shock absorber 914/4 or /6 |
IAA1963 |
Jan 15 2016, 01:21 PM
Newbie Group: Members Posts: 46 Joined: 8-October 11 Member No.: 13,652 Region Association: None |
Hello,
The parts cataloge is showing two different part numbers for the rear shock absorbers - one for the /6 and the other one for the /4. Can someone tell me if this new part number PCG33305150 is for the /4 or /6 rear shock absorbers? Thanks, Mark |
Mark Henry |
Jan 15 2016, 01:38 PM
Hello, The parts cataloge is showing two different part numbers for the rear shock absorbers - one for the /6 and the other one for the /4. Can someone tell me if this new part number PCG33305150 is for the /4 or /6 rear shock absorbers? Thanks, Mark I don't know if there is a difference. The big difference is the brand and the quality differences. KYB are called "Kill Your Backs" for good reason, they are cheap because they are junk, way too hard in a bad way. Boge (Sachs) are ok if you are on a budget and performance is not a big deal. Bilstein or Koni are the favored brands. Quality, rebuildable and they have adjustable spring perches are just some of the top reasons. Note the rear springs also come into play in the handling department. |
Cairo94507 |
Jan 15 2016, 05:10 PM
Michael Group: Members Posts: 9,822 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California |
Yup. what he just said.
IAA1963 |
Jan 22 2016, 10:23 AM
Thank you.
KYB are not an option anyway. I am restoring an original /6 and want to have it as it left the factory in 1970. According to the partsbook this would be Boge, I guess. |
johnhora |
Jan 22 2016, 11:38 AM
Senior Member Group: Members Posts: 867 Joined: 7-January 03 From: Derby City KY Member No.: 107 Region Association: None |
Mark...
Yes the standard factory delivered shock would have been the Boge. Koni and Bilstein were available as an option in the Sports Purposes packages. Your 914-6 may have been delivered with any of these and the only way to know would be to have a cardex build sheet. Good luck with your restoration! Please show us some picture of your progress. Regards....John |
Mark Henry |
Jan 22 2016, 12:27 PM
Shocks and struts are a simple bolt on and most CW judges will give them a pass.
Most likely a replacement Boge struts/shock from today is not OE correct. |
IAA1963 |
Jan 26 2016, 03:56 PM
So finally I bought this pair:
johnhora |
Jan 26 2016, 05:41 PM
Mark...
Those will work great. Good choice. Perfect stock replacement. |
Krieger |
Jan 26 2016, 07:18 PM
Advanced Member Group: Members Posts: 4,726 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None |
Nice looking!
IAA1963 |
Feb 7 2016, 05:23 AM
Final fittings before the painter starts to get it back to tangerine ...
Lo-Fi Version | Time is now: 8th June 2024 - 02:31 AM |
