what kind of fuel filter for carbs |
rosenfe |
Feb 6 2016, 02:37 PM
Senior Member Group: Members Posts: 557 Joined: 14-October 13 From: northern california Member No.: 16,512 Region Association: None |
on my 73 2.o with weber 34,can i use a clear plastic inline filter or stick with stock filter that came with fi.
SKL1 |
Feb 6 2016, 02:53 PM
Senior Member Group: Members Posts: 1,602 Joined: 19-February 11 From: north Scottsdale Member No.: 12,732 Region Association: Upper MidWest |
I just use a generic in line fuel filter from any local auto parts store. Works fine. Not sure with the low pressure with carbs the FI filter will work.
r_towle |
Feb 6 2016, 04:58 PM
Custom Member Group: Members Posts: 24,585 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
I like the cheap inline ones that I can see up in the engine bay...
Also one before the pump. I went with a re-usable one from summit because I had lots of rust in my replacement tank....it's simple to open and clean, I put shut offs on either side of it... |
rosenfe |
Feb 6 2016, 07:54 PM
i too have thought that with low pressure fi filter will not work,in fact it didnt.
rhodyguy |
Feb 7 2016, 11:03 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,085 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
By 'will not work', what do you mean? I run one with carbs that has the same size nipples and it functions just fine. Single tangerine supply, no return and the same size modern fuel line from tank outlet to the 'second' weber.
Lo-Fi Version | Time is now: 2nd June 2024 - 04:28 PM |
