95 ' F I Chevy 4.3 Ltr, How much power can you get from this engine |
flmont |
Feb 17 2016, 10:56 PM
Senior Member Group: Members Posts: 879 Joined: 21-October 08 From: Tucson,Az Member No.: 9,676 Region Association: Southwest Region |
I have a 95' 4.3 Ltr FI engine that needs rebuilt,..what kind of power can U get from these engine's with factory ECU,..and spider FI system..?? Thanks
Mueller |
Feb 17 2016, 11:12 PM
I'd think asking that question on a truck forum that the motor came from you'd get more answers. Can the ecu be chipped or reprogrammed ¿
Are you willing to change the pistons rods or heads? $500 rebuild budget or 3 times that amount¿ |
messix |
Feb 18 2016, 12:46 AM
AKA "CLUTCH KILLER"! Group: Members Posts: 6,995 Joined: 14-April 05 From: between shit kickers and pinky lifters/ puget sound wa.north of Seattle south of Canada Member No.: 3,931 Region Association: Pacific Northwest |
it depends on what version you have.
you will need to look here to figure out what engine you have https://en.wikipedia.org/wiki/General_Motor...C2%B0_V6_engine then with less accessories and less restrictive exhaust you might add 10-15% in hp also note how low these engines make their power, these are designed for torque to be used in trucks. |
jsaum |
Feb 18 2016, 09:47 AM
Senior Member Group: Members Posts: 530 Joined: 12-June 07 From: Everett, WA Member No.: 7,809 Region Association: None |
My boat has the marine 4.3 it makes 205hp.
matthepcat |
Feb 18 2016, 10:37 AM
Meat Popsicle Group: Members Posts: 1,462 Joined: 13-December 09 From: Saratoga CA Member No.: 11,125 Region Association: Northern California |
Just build it to GMC Syclone/Typhoon specs with a turbo for best power.
mgp4591 |
Feb 18 2016, 10:48 AM
914 Guru Group: Members Posts: 5,380 Joined: 1-August 12 From: Salt Lake City Ut Member No.: 14,748 Region Association: Intermountain Region |
jmill |
Feb 18 2016, 01:47 PM
Green Hornet Group: Members Posts: 2,449 Joined: 9-May 08 From: Racine, Wisconsin Member No.: 9,038 Region Association: Upper MidWest |
Go to the S10 Forums. Lots of high performance goodies are available for that engine (check Summit and JEGS). You can easily get 260 HP. I had one in an S10 Blazer. The turbo'd aluminum block GNX version would be insane in a teener.
messix |
Feb 18 2016, 02:37 PM
Go to the S10 Forums. Lots of high performance goodies are available for that engine (check Summit and JEGS). You can easily get 260 HP. I had one in an S10 Blazer. The turbo'd aluminum block GNX version would be insane in a teener. Gnx has the Buick 3.8 Not the same engine |
jmill |
Feb 18 2016, 06:45 PM
Bulldog9 |
Feb 18 2016, 07:21 PM
Senior Member Group: Members Posts: 705 Joined: 21-August 13 From: United States Member No.: 16,283 Region Association: MidAtlantic Region |
Gnx has the Buick 3.8 Not the same engine Well dang. I thought the were based off the same block. My bad. Yeah, totally different engine. The 3.8 is a V-6 that dates back to the 60's as a 90degree V-6. A very stout motor...... The 4.3 is derived from the 350 V-8 minus two cylinders. Low rev, high torque. IMO, the 3.8 used in the GNX is a much better motor, even NA. In its later years was roller rocker and lifters, very smooth great Fuel Economy and an easy 200K. One benefit of the 4.3 was the plug and play of Pistons, Connecting Rods, Lifters, Rockers, Bearings, Timing chain, valves from the 350..... I'd love to get my hands on one of the old Buick or Olds all aluminum V-8's. I had one in an Opel GT project years ago........ Back then they were all over the place. Now, impossible to find.... Ah the good old days. |
Mike Bellis |
Feb 18 2016, 07:34 PM
Resident Electrician Group: Members Posts: 8,345 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None |
I would go with a 5.7L V8 and reap the benefit of cheaper parts and more power.
spaceshuttle |
Feb 18 2016, 09:32 PM
Member Group: Members Posts: 73 Joined: 25-November 06 From: SouthCarolina Member No.: 7,258 |
flmont |
Feb 18 2016, 10:02 PM
Yea I know about the v8's,...but I have the 6 if I could build close to 300HP,..i would be happy with that, but I do want FI,....Otherwise its the subie EZ30R ...not sure what kinda pwr that can reach stk is 240 or so,..
spaceshuttle |
Feb 18 2016, 10:10 PM
Mike Bellis |
Feb 18 2016, 10:19 PM
Yea I know about the v8's,...but I have the 6 if I could build close to 300HP,..i would be happy with that, but I do want FI,....Otherwise its the subie EZ30R ...not sure what kinda pwr that can reach stk is 240 or so,.. Look again. That is a 6. 4.3 Chevy. Confident that it will be over 450HP But how much did you spend on it? |
spaceshuttle |
Feb 18 2016, 10:21 PM
Yea I know about the v8's,...but I have the 6 if I could build close to 300HP,..i would be happy with that, but I do want FI,....Otherwise its the subie EZ30R ...not sure what kinda pwr that can reach stk is 240 or so,.. Look again. That is a 6. 4.3 Chevy. Confident that it will be over 450HP But how much did you spend on it? (IMG:style_emoticons/default/av-943.gif) Way too much but it sure is fun! I had the engine and thought it would be fun in a 1750lb. car |
Mike Bellis |
Feb 18 2016, 10:29 PM
Look again. That is a 6. 4.3 Chevy. Confident that it will be over 450HP (IMG:style_emoticons/default/av-943.gif) Way too much but it sure is fun! I had the engine and thought it would be fun in a 1750lb. car Might be fun and all but a V8 will make more power for less money. So it all depends on your budget... |
flmont |
Feb 18 2016, 10:33 PM
I think 300-350 HP is about right for a 914,..being I have the engine a supposed vortec at 200hp should'nt take much to get 250 275,..,..the subie engines are around 1500.00 plus all the ECU expense,..at near 2500.00 from outfront,..hell 4 k already,..and I
have all that already for 250.00 bucks |
spaceshuttle |
Yea I know about the v8's,...but I have the 6 if I could build close to 300HP,..i would be happy with that, but I do want FI,....Otherwise its the subie EZ30R ...not sure what kinda pwr that can reach stk is 240 or so,.. Look again. That is a 6. 4.3 Chevy. Confident that it will be over 450HP But how much did you spend on it? (IMG:style_emoticons/default/av-943.gif) Way too much but it sure is fun! I had the engine and thought it would be fun in a 1750lb. car I do have another one that I broke the crank in. I have a set of the little Brody aluminum heads and it has a kickin little .600 cam. If you are interested, I would sell you some of the parts. It made 300 with just the heads and the cam. |
flmont |
Feb 18 2016, 10:35 PM
Mike,..your car is 325 HP are u happy with that,..and with the handeling,..of course your set up is more than stk,..I know..
Lo-Fi Version | Time is now: 1st June 2024 - 04:16 PM |
