Going to visit Qarl - pictures, also pictures of trans cooler install |
iamchappy |
Mar 30 2005, 12:00 AM
It all happens so fast! Group: Members Posts: 4,893 Joined: 5-November 03 From: minnetonka, mn Member No.: 1,315 Region Association: Upper MidWest |
Visiting with Qarl this Sunday, I will let you know my impressions of the Elise ride.
I am closing in on finishing the turbo install, just mounted the transmission cooler and am only a few hours away from taking it for a spin. It will have to wait until I return from Florida next week. Attached image(s) |
iamchappy |
2
Attached image(s) |
iamchappy |
Mar 30 2005, 12:01 AM
3
Attached image(s) |
iamchappy |
Mar 30 2005, 12:02 AM
4
Attached image(s) |
Qarl |
Mar 31 2005, 12:44 PM
Shriveled member Group: Benefactors Posts: 5,233 Joined: 8-February 03 From: Florida Member No.: 271 Region Association: None |
Much impoved ground clearance from the old setup.
And the install looks very clean! Regards, Qarl |
Root_Werks |
Mar 31 2005, 12:57 PM
Village Idiot Group: Members Posts: 8,331 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest |
As always when I see your 914..... (IMG:http://www.914world.com/bbs2/html/emoticons/drooley.gif)
Aaron Cox |
Mar 31 2005, 01:03 PM
Professional Lawn Dart Group: Retired Admin Posts: 24,541 Joined: 1-February 03 From: OC Member No.: 219 Region Association: Southern California |
vey nice!!!!
can you still fit the targa in the trunk? |
john rogers |
Mar 31 2005, 01:21 PM
Senior Member Group: Members Posts: 1,525 Joined: 4-March 03 From: Chula Vista CA Member No.: 391 |
I mounted my tranny cooler in the floor of the trunk and I found that when the muffler was installed it turned the cooler into a tranny heater even with the pipes wrapped and an aluminum deflector similar to what you have. I finally stopped using the muffer system and use inserts in the stingers and the heat issue went away. I guess there is a huge amount of heat trapped by that rear valence hanging down under the bumper.? Do you have a temp gauge as I did not see a wire running from the tranny? Also how do you run the pump? Several shops said to switch the pump so the tranny could get a little heat before tuning on the pump as they burn out the motor with cold Swepco? But then several others said just wire it so it runs when the engine runs? I used a switch.
rick 918-S |
Mar 31 2005, 01:49 PM
Hey nice rack! -Celette Group: Members Posts: 20,474 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
iamchappy |
Apr 3 2005, 07:42 PM
I will be using a switch to turn on the tranmission pump when I think its needed, I have been using stainless steel to shield and reflect heat away from the transmission cooler. The cooler is downstream of the intercoolers fan ducting so air is being blown through it. When I get back home I will get some sides around it which will direct a good amount of air through it.
(IMG:http://www.914world.com/bbs2/html/emoticons/boldblue.gif) Now the fun news, I had a ride in the Lotus and came away with a big smile, Qarls got himself a fun toy, the car is very tight and has a wonderful note to the engine, the dual cam kick in is great fun and very coooool. More rides to come..... (IMG:http://www.914world.com/bbs2/html/emoticons/mueba.gif) |
rick 918-S |
Apr 3 2005, 09:26 PM
You boys know better! (IMG:http://www.914world.com/bbs2/html/emoticons/thisthreadisworthlesswithoutpics.gif)
Unless it was illegal! (IMG:http://www.914world.com/bbs2/html/emoticons/happy11.gif) |
Lo-Fi Version | Time is now: 3rd June 2024 - 04:50 AM |
