Coat hook held on by magic?, How to break the spell? |
bretth |
Apr 13 2016, 08:23 PM
Senior Member Group: Members Posts: 899 Joined: 23-June 15 From: Central TX Member No.: 18,882 Region Association: Southwest Region |
Took off the upper seat belt bolt and the center sheet metal screw in the vinyl trim but it is somehow still attached under the coat hook. I can rotate the bottom part of the trim panel forward about an inch but that's it because i rather not crack my trim with more force.
Magic wand needed. Brett |
ejm |
Apr 13 2016, 08:26 PM
I can see the light at the end of the tunnel Group: Members Posts: 2,695 Joined: 3-February 03 From: Massachusetts Member No.: 224 Region Association: None |
Pry the rubber cover up and off the coat hook and remove the screw that holds the metal inner hook to the car
bretth |
Apr 14 2016, 06:32 PM
Lo-Fi Version | Time is now: 10th June 2024 - 11:12 PM |
