Floor pans, With or With not? |
JB 914 |
Apr 3 2005, 10:20 PM
Daddy! Finish my car NOW!!! Group: Members Posts: 1,593 Joined: 26-September 04 From: Garden Grove, CA Member No.: 2,831 |
I'm painting the floor pans this week. PO seems to have put some type of sound deadening stuff like tar or is that from the factory? i don't think i've got that on my 71.
So, since i'm POR-15'n the floor pan do i need to remove that first? or can i simply clean up the loose bits and go right over it? i'm planning on doing the underside of the floor pans too. Also, what could i use to help deaden the sound after i paint it? |
CptTripps |
Apr 3 2005, 10:27 PM
:: Punch and Pie :: Group: Members Posts: 3,584 Joined: 26-December 04 From: Mentor, OH Member No.: 3,342 Region Association: Upper MidWest |
Take it down to bare metal BEFORE you POR-15 it. If not, you'll just be making a rust-sandwitch.
I used 3-4 coats of Herculiner. Others will have opinions about other deadeners like Dynamat. This stuff will also work awesome! http://cgi.ebay.com/ws/eBayISAPI.dll?ViewI...item=5763375125 |
mk114 |
Apr 3 2005, 10:32 PM
LOST in NO space (my garage) Group: Members Posts: 330 Joined: 29-March 05 From: Salt Lake Utah Member No.: 3,835 |
I used bed liner from any parts store for around 29 to 59 bucks the roll on kind (use a scraper to make it smooth then I added a layer of sound insulation (11.99) a roll)
http://www.herculiner.com/ |
Gint |
Apr 3 2005, 10:33 PM
Mike Ginter Group: Admin Posts: 16,082 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains |
The factory use tar in all 914's on the floorpans (inside the cabin). You'll have to remove it before you POR15. Heat gun and a putty knife work great. Brake cleaner will clean the remnants that are too tiny or in corners for putty knife work. |
Lo-Fi Version | Time is now: 3rd June 2024 - 03:48 AM |
